Hi all.
I'm looking to write a readPixel function for the Adafruit NeoMatrix library.
So far I have... (which you will note is exactly the same as the drawPixel function just using getPixelColor at the end)
uint32_t Adafruit_NeoMatrix::readPixel(int16_t x, int16_t y) const {
if((x < 0) || (y < 0) || (x >= _width) || (y >= _height)) return 0; //specified pixel is outside limits
int16_t t;
switch(rotation) {
case 1:
t = x;
x = WIDTH - 1 - y;
y = t;
case 2:
x = WIDTH - 1 - x;
y = HEIGHT - 1 - y;
case 3:
t = x;
x = y;
y = HEIGHT - 1 - t;
int tileOffset = 0, pixelOffset;
if(remapFn) { // Custom X/Y remapping function
pixelOffset = (*remapFn)(x, y);
} else { // Standard single matrix or tiled matrices
uint8_t corner = type & NEO_MATRIX_CORNER;
uint16_t minor, major, majorScale;
if(tilesX) { // Tiled display, multiple matrices
uint16_t tile;
minor = x / matrixWidth; // Tile # X/Y; presume row major to
major = y / matrixHeight, // start (will swap later if needed)
x = x - (minor * matrixWidth); // Pixel X/Y within tile
y = y - (major * matrixHeight); // (-* is less math than modulo)
// Determine corner of entry, flip axes if needed
if(type & NEO_TILE_RIGHT) minor = tilesX - 1 - minor;
if(type & NEO_TILE_BOTTOM) major = tilesY - 1 - major;
// Determine actual major axis of tiling
if((type & NEO_TILE_AXIS) == NEO_TILE_ROWS) {
majorScale = tilesX;
swap(major, minor);
majorScale = tilesY;
// Determine tile number
if((type & NEO_TILE_SEQUENCE) == NEO_TILE_PROGRESSIVE) {
// All tiles in same order
tile = major * majorScale + minor;
// Zigzag; alternate rows change direction. On these rows,
// this also flips the starting corner of the matrix for the
// pixel math later.
if(major & 1) {
corner ^= NEO_MATRIX_CORNER;
tile = (major + 1) * majorScale - 1 - minor;
// Index of first pixel in tile
tileOffset = tile * matrixWidth * matrixHeight;
} // else no tiling (handle as single tile)
// Find pixel number within tile
minor = x; // Presume row major to start (will swap later if needed)
major = y;
if(corner & NEO_MATRIX_RIGHT) minor = matrixWidth - 1 - minor;
if(corner & NEO_MATRIX_BOTTOM) major = matrixHeight - 1 - major;
// Determine actual major axis of matrix
if((type & NEO_MATRIX_AXIS) == NEO_MATRIX_ROWS) {
majorScale = matrixWidth;
swap(major, minor);
majorScale = matrixHeight;
// Determine pixel number within tile/matrix
if((type & NEO_MATRIX_SEQUENCE) == NEO_MATRIX_PROGRESSIVE) {
// All lines in same order
pixelOffset = major * majorScale + minor;
if(major & 1) pixelOffset = (major + 1) * majorScale - 1 - minor;
else pixelOffset = major * majorScale + minor;
return getPixelColor(tileOffset + pixelOffset);
This all compiles fine.
What I am stuck on is essentially all the different colour spaces being used. Within the adafruit implementation they exist as 3x8bit rgb values, 16bit adafruit gfx colourspace and 32bit WS2812 colourspace (which is actually 24bit padded out). You can understand the difficulty I am having getting past this!
So my question is this:
Now that I have my matrix.readPixel(x,y) function how can I implement it with matrix.drawPixel(x,y,c) to simply draw back what has been read?
