I'm using MI0283QT-2 from www.watterott.com. The display works well, but need its time. So for movig object I'm looking for a possibility to reinstall the graphic content after displaying without redrawing the hole screen.
For a radar plot I'm looking for an enhanced libary function to read the graphics memory out something like:
Color = readPixel(x,y);
array(...) = readRect(x1,y1,x2,y2);
... so having the data for the partial reinstall/redraw
Another Option could be drawing objects in inverting mode - so with a Xor-bitset.
writePixelXor(x,y,color);
... so with a second indentical command the object disapears.
I've asked watterott, but the don't see a solution.
I've tried to hack the graphics libary, but it ended up in a mess.
Is ther sombody out ther, how can help?
I Googled "MI0283QT-2" and found a bare 3.3V module. There is a PDF for the MI0283QT-2 and another PDF for the replacement model.
All the signals are on the 47-way flex-ribbon. If you select the IM# pins for 0011, you get the 8080-8 interface.
The MCUFRIEND_kbv library will work with the HX8347-D controller. But you must #define the SUPPORT_8347D in the MCUFRIEND_kbv.cpp file.
I know that MCUFRIEND_kbv works. I am fairly certain that Adafruit_TFTLCD library should work too.
Both libraries support readPixel(). MCUFRIEND_kbv supports readGRAM() too. i.e. read a rectangular block.
Note that you have a bare 3.3V module. It will be damaged by 5V signals.
If you want to use IM#=0100 the display should work in 4-wire SPI mode. I have written an appropriate library but it is untested for "read".
David.
