Reads volts input convert to Liters
Hello everyone.
I have a problem reading accurately from an analog input where 0-3 volts will be received.
Basically the system reads the voltage generated by an Aqua Plumb 0-3V range depending on the water lever, compared to calibration dry/wet.
The problem I have is that I want to have an accurate input signal, and stable, that can I can pass to the arduino so it can process with a function like map.
I have done the program similar to the tutorial 9, but when gettings readings a small change affects the outcome with too much offset.
ReadAnalogVoltage
Reads an analog input on pin 0, converts it to voltage, and prints the result to the serial monitor.
Graphical representation is available using serial plotter (Tools > Serial Plotter menu)
Attach the center pin of a potentiometer to pin A0, and the outside pins to +5V and ground.
This example code is in the public domain.
// the setup routine runs once when you press reset:
// initialize serial communication at 9600 bits per second:
// the loop routine runs over and over again forever:
// read the input on analog pin 0:
int sensorValue = analogRead(A0);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = sensorValue * (5.0 / 1023.0);
// print out the value you read:
Serial.println(voltage);
Pasols:
Are you using that program with a potentiometer or connected to your own sensor?
Post a typical sequence of the values you are getting.
Can you check the voltage from your sensor with a multimeter?
Post a link to the datasheet for your sensor.
For the future please use the code button </> so your code looks like this and is easy to copy to a text editor. See How to use the Forum
…R
should be this, I think..
  float voltage = (float)sensorValue * (5.0 / 1023.0);
Tom... :slight_smile:
To measure a 0-3volt signal with the highest resolution/stability, Aref must be dropped to a stable 3volt.
That can be done, for a 5volt Arduino, by connecting the 3.3volt pin to the Aref pin with a 3k3 resistor.
You MUST then also set Aref to EXTERNAL, otherwise there is a danger of damaging Aref.
https://www.arduino.cc/en/Reference/AnalogReference
Don't use an intermediate step (voltage).
Convert A/D value straight to liters.
float liters = analogRead(A0) * x.xxx;
If you have the 1meter (1mm resolution) version of the sensor, and you want to display level (not liters) it might be better to drop Aref to 1.024*3volt.
With a 3.072volt Aref, one A/D value is exactly 1mm.
No damaging voltage or mapping conversion needed.
You can make a 3.072volt Aref with a ~2.5k resistor between 3.3volt pin and the Aref pin.
Leo..
