I feel like the answer to this has to be obvious and I'm going to feel really stupid. I tried integrating my first sd card into my first project. I tried the example ReadWrite by itself first and that worked fine. I then incorporated that into my code, but it wouldn't create the text file. I then went back to the ReadWrite example and the only change that I made was to the file name. I changed it from test.txt to waterData.txt and it had the same problem. It wouldn't create the text file.
Here is the waterData code. This gives me the following output in the serial monitor.
Initializing SD card...initialization done.
error opening waterData.txt
#include <SPI.h>
#include <SD.h>
File myFile;
Serial.print("Initializing SD card...");
if (!SD.begin(53)) {
Serial.println("initialization failed!");
while (1);
Serial.println("initialization done.");
// open the file. note that only one file can be open at a time,
// so you have to close this one before opening another.
myFile = SD.open("waterData.txt", FILE_WRITE);
// if the file opened okay, write to it:
if (myFile) {
Serial.print("Writing to waterData.txt...");
myFile.println("testing 1, 2, 3.");
// close the file:
myFile.close();
Serial.println("done.");
// if the file didn't open, print an error:
Serial.println("error opening waterData.txt");
// re-open the file for reading:
myFile = SD.open("waterData.txt");
if (myFile) {
Serial.println("waterData.txt:");
// read from the file until there's nothing else in it:
while (myFile.available()) {
Serial.write(myFile.read());
// close the file:
myFile.close();
// nothing happens after setup
Here is the test code. This gives the following in serial monitor.
Writing to test.txt...done.
test.txt:
testing 1, 2, 3.
#include <SPI.h>
#include <SD.h>
File myFile;
while (1);
myFile = SD.open("test.txt", FILE_WRITE);
if (myFile) {
Serial.print("Writing to test.txt...");
// close the file:
myFile.close();
Serial.println("error opening test.txt");
myFile = SD.open("test.txt");
if (myFile) {
Serial.println("test.txt:");
// close the file:
myFile.close();
Is there something obvious that I'm overlooking? I can't for the life of me think of why this change would cause such problems unless I keep making a typo or keep forgetting to change a file name somewhere in the code.
