This need was researched several years ago and a solution is now needed. I had not looked at the information for over a year.
When I saw the schematic first referred to my question was why not 5v. That let me to posting the question. I am not trying to be difficult. I am trying to make something that will work.
Here is what I got from their tech support when this issue first came up:
Following to your inquiry, we would recommend to use Parker O-lube
silicone grease or DMS-T46 or T51. This type of grease is used by most
of our customer without problems. In fact the basic recommendation are
to use a silicone oil (or preferably grease) with high viscosity and
high molecular weight. In this case the size of the molecules are big
enough to limit the penetration of the grease inside our protective
silicone gel which is over the die. In terms of contaminants, the
silicon grease must be free of halogenures (Cl content < 50 ppm) to
reduce the risk of bond pad corrosion. On the other hand, don't forget
that whatever the material you will use, as soon as you put something on
our gel you have a high probability to see some offset drift. This is
coming from additional mechanical stress and/or gel swelling. The amount
of gel and global mechanical design are usually also part of the offset
drift.
Protecting pressure sensors with a silicon grease is definitely the best
way to use our products in harsh media. We don't have so much experience
in how to implement this solution 'industrially'. The grease fill is
done under vacuum to avoid air bubbles. Usually, an offset calibration
is necessary because the grease brings some mechanical stress that may
shift the offset value. This solution was tested and seems conclusive.
Usually in a water measurement application, a head tube is used. This is
simply a piece of tubing between the sensor and the container in which
the water level or pressure needs to be measured.
Air is trapped in the tube and this isolates the sensor from the liquid
water.
As said, you can use any silicon oil or preferably grease from other
suppliers with high viscosity and high molecular weight.
I would like refer to the following application note that would be worth
to be considered.
AN3728: Media Compatibility for IPS PRT Pressure Sensors
http://www.freescale.com/files/sensors/doc/app_note/AN3728.pdf
AN1516: Liquid Level Control Using a Pressure Sensor
http://www.freescale.com/files/sensors/doc/app_note/AN1516.pdf
AN1950: Water Level Monitoring
http://www.freescale.com/files/sensors/doc/app_note/AN1950.pdf
The last app note discusses using the sensor in a washing machine.
My question was a honest attempt to educate myself. I don't understand the seeming ridicule from Bob.
