Real Time Clock Set-up
Hey there! :slight_smile: Can anyone please help me on how to setup the TimeRTC code? I want to set it up in the current time of my PC. Thanks here’s the code…
 * TimeRTC.pde
 * example code illustrating Time library with Real Time Clock.
#include <Time.h>
#include <Wire.h>
#include <DS1307RTC.h>  // a basic DS1307 library that returns time as a time_t
void setup()  {
  setSyncProvider(RTC.get);   // the function to get the time from the RTC
  if(timeStatus()!= timeSet)
     Serial.println("Unable to sync with the RTC");
     Serial.println("RTC has set the system time");
   digitalClockDisplay();
void digitalClockDisplay(){
  // digital clock display of the time
  Serial.print(hour());
  printDigits(minute());
  printDigits(second());
  Serial.print(" ");
  Serial.print(day());
  Serial.print(" ");
  Serial.print(month());
  Serial.print(" ");
  Serial.print(year());
void printDigits(int digits){
  // utility function for digital clock display: prints preceding colon and leading 0
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
  Serial.print(digits);
There's a SetTime example with that library you're using: it sets the time to the time you compiled the sketch.
Yes. It works but i’m having this kind of problem
How do I change it to the current time and date?
here is the code…
 * TimeRTCSet.pde
 * RTC clock is set in response to serial port time message
 * A Processing example sketch to set the time is inclided in the download
#include <Time.h>
#include <Wire.h>
void setup()  {
  if(Serial.available())
     time_t t = processSyncMessage();
     if(t >0)
        RTC.set(t);   // set the RTC and the system time to the received value
        setTime(t);
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(" ");
  Serial.print(":");
  if(digits < 10)
    Serial.print('0');
/*  code to process time sync messages from the serial port   */
#define TIME_MSG_LEN  11   // time sync to PC is HEADER followed by unix time_t as ten ascii digits
#define TIME_HEADER  'T'   // Header tag for serial time sync message
time_t processSyncMessage() {
  // return the time if a valid sync message is received on the serial port.
  while(Serial.available() >=  TIME_MSG_LEN ){  // time message consists of a header and ten ascii digits
    char c = Serial.read() ;
    Serial.print(c);
    if( c == TIME_HEADER ) {
      time_t pctime = 0;
      for(int i=0; i < TIME_MSG_LEN -1; i++){
        c = Serial.read();
        if( c >= '0' && c <= '9'){
          pctime = (10 * pctime) + (c - '0') ; // convert digits to a number
      return pctime;
  return 0;
