Real-Time Temperature Sensor readings
We need real-time voltage readings from our temp. sensor while running if statement that is delay activated by an RFID. The temperature readings from the sensor are very inconsistent too even without any change in the surrounding temperature. I need help on getting a consistent reading and avoiding long delays. Pls help!! Here’s my code:
// Modified by Worapoht K.
#include <SoftwareSerial.h>
int val = 0;
char code[10];
int bytesread = 0;
int sensor=2;
int val1;
#define rxPin 8
#define txPin 9
// RFID reader SOUT pin connected to Serial RX pin at 2400bps to pin8
Serial.begin(2400); // Hardware serial for Monitor 2400bps
pinMode(3,OUTPUT);
pinMode(4,OUTPUT);
pinMode(2,OUTPUT); // Set digital pin 2 as OUTPUT to connect it to the RFID /ENABLE pin
digitalWrite(2, LOW); // Activate the RFID reader
SoftwareSerial RFID = SoftwareSerial(rxPin,txPin);
RFID.begin(2400);
if((val = RFID.read()) == 10)
{ // check for header
bytesread = 0;
while(bytesread<10)
{ // read 10 digit code
val = RFID.read();
if((val == 10)||(val == 13))
{ // if header or stop bytes before the 10 digit reading
break; // stop reading
code[bytesread] = val; // add the digit
bytesread++; // ready to read next digit
if(bytesread == 10)
{ // if 10 digit read is complete
val1=analogRead(sensor);
Serial.print("temperature value: ");
Serial.println(val1);
Serial.print("TAG code is: "); // possibly a good TAG
Serial.println(code); // print the TAG code
digitalWrite(3,HIGH);
digitalWrite(4,LOW);
delay(2000);
digitalWrite(4,HIGH);
delay(2000);
digitalWrite(3,LOW);
delay(2000);
delay(2000);
bytesread = 0;
delay(500); // wait for a second
I would try putting a bypass capacitor (0.1uf or so) across the sensor output pin to ground. It helped me a bit.
