at my current project the wiring is fixed & no more PWM Pin is free to use. So i need to realize PWM softwarewise. The challenge is, that the PWM Signal should be switched on just for 3 milliseconds, then switched off for 20ms or so. The default PWM Frequency at my sketch is about 1 kHz, so the resolution isnt high enough for this short on-time.
Does anybody know how to increase the PWM frequency by code?
I really looking forward to your Input
The current Code:
unsigned long openDuration_opentest1 =3000; //total on- time period in useconds for Output
unsigned long pauseDuration_opentest1 = 20000; // cycle time
unsigned long previousMicros=0;
unsigned long currentMicros =0;
ISR(TIMER0_COMPA_vect)
PORTC = B01000000;
ISR(TIMER0_COMPB_vect)
PORTC = B00000000;
void softpwm(byte pwm)
switch (pwm)
case 0 : TIMSK0 &= ~(_BV(OCIE0B) | _BV(OCIE0A));
PORTC = B00000000; //Pin 31,33,35,37 LOW
case 255 : TIMSK0 &= ~(_BV(OCIE0B) | _BV(OCIE0A));
PORTC = B01000000; //Pin 31,33,35,37 HIGH
default : OCR0A = 3;
OCR0B = pwm;
TIMSK0 |= _BV(OCIE0B) | _BV(OCIE0A);
void setup(){
DDRC = B01010101; //Register Pin 31,33,35,37 as output for fast switching
void loop(){
void opentest1() {
void opentest1() {
currentMicros = micros();//starts timer
while (currentMicros - previousMicros <= openDuration_opentest1) {
softpwm(160);
while (currentMicros - previousMicros <= pauseDuration_opentest1) {
softpwm(0); //switches off all injectors
while (currentMicros - previousMicros > pauseDuration_opentest1){
previousMicros = currentMicros;
If all PWM pins are in use then also all timers are in use. If you abuse one timer for a software PWM then you loose all the hardware PWM signals for that timer.
The PWM Pins are in use, but do not need the PWM function of the pin (using simple I/O for TFT).
For my understand, it wouldnt be a problem, if this pins do los their PWM function.
Is there a possebility to increase the PWM Frequency of the Software-pwm?
Then using this sketch, I get the full Input Voltage at the Output.
My goal is, to use an inductive Load at "reduced voltage" by using PWM Signal.
My challenge is, that we have two combined PWM Signals working accordingly.
The inductive load should be switched on every 20 ms for 3 ms. So for this example 3 ms on, 17 ms off.
Then the Inductive load is switched on, it should be switched on by PWM with ~ 61% duty, to reduce the Voltage from 13V to about 8V.
So we need an PWM with high resolution, which is able to realize the 61% duty at 3 ms "on time".
What do you exatly mean with feedback?
If you mean feedback for control cycle: The Output Voltage does not need to be controlled, we just need to set it up to 8V one time, bcs. the Input Voltage stays constantly.
