Hey,
I am building a circuit that consists of 5 servos that move based on the input given by 2 I2C sensors (Vl53L0x) sensors. I set up the i2C channels for the sensors separately and then run the program.
Goal of the Program:
- if an object is positioned in the center of the two sensors and gets close to the sensor, the servos would rotate at a larger angle step by step.
I am experiencing quite a few issues with assembling the circuit.
Here are my issues:
Sometimes the two sensors don't start up even if the circuit connections and code are correct. I have to manually redo the I2C channels for both sensors and then it works. Why does this happen?
My servos dont move or if they do, it is not fast or they move irregularly. Why does that happen?
Here is my code:
> #include "Adafruit_VL53L0X.h"
> #include <Servo.h>
> Servo myservo1;
> Servo myservo_index;
> Servo myservo_middle;
> Servo myservo_ring_small;
> Servo myservo_thumb;
> // address we will assign if dual sensor is present
> #define LOX1_ADDRESS 0x30
> #define LOX2_ADDRESS 0x2A
> // set the pins to shutdown
> #define SHT_LOX1 7
> #define SHT_LOX2 6
> // this holds the measurement
> VL53L0X_RangingMeasurementData_t measure1;
> VL53L0X_RangingMeasurementData_t measure2;
> // objects for the vl53l0x
> Adafruit_VL53L0X lox1 = Adafruit_VL53L0X();
> Adafruit_VL53L0X lox2 = Adafruit_VL53L0X();
> //int list1[3];
> //int list2[3];
> int sensor1 = 0;
> int sensor2 = 0;
> int index = 0;
> int avg = 0;
> int pos = 0;
> int fing_pos = 30;
> int curr_pos = 90;
> int pos_finger = 60; // finger is at rest position at 60 deg (claw shape)
> unsigned long startTime_display = 0;
> unsigned long interval_display = 300;
> Reset all sensors by setting all of their XSHUT pins low for delay(10), then set all XSHUT high to bring out of reset
> Keep sensor #1 awake by keeping XSHUT pin high
> Put all other sensors into shutdown by pulling XSHUT pins low
> Initialize sensor #1 with lox.begin(new_i2c_address) Pick any number but 0x29 and it must be under 0x7F. Going with 0x30 to 0x3F is probably OK.
> Keep sensor #1 awake, and now bring sensor #2 out of reset by setting its XSHUT pin high.
> Initialize sensor #2 with lox.begin(new_i2c_address) Pick any number but 0x29 and whatever you set the first sensor to
> void setID() {
> // initing LOX1
> if(!lox1.begin(LOX1_ADDRESS)) {
> // Serial.println(F("Failed to boot first VL53L0X"));
> while(1);
> delay(10);
> // activating LOX2
> digitalWrite(SHT_LOX2, HIGH);
> delay(10);
> //initing LOX2
> if(!lox2.begin(LOX2_ADDRESS)) {
> // Serial.println(F("Failed to boot second VL53L0X"));
> while(1);
> void read_dual_sensors() {
> lox1.rangingTest(&measure1, false); // pass in 'true' to get debug data printout!
> lox2.rangingTest(&measure2, false); // pass in 'true' to get debug data printout!
> // print sensor one reading
> Serial.print(F("1_: "));
> if(measure1.RangeStatus != 4) { // if not out of range
> Serial.print(measure1.RangeMilliMeter);
> sensor1 = measure1.RangeMilliMeter;
> } else {
> // Serial.print(F("Out of range"));
> Serial.print("1000");
> Serial.print(F(" "));
> // print sensor two reading
> Serial.print(F("2: "));
> if(measure2.RangeStatus != 4) {
> Serial.print(measure2.RangeMilliMeter);
> sensor2 = measure2.RangeMilliMeter;
> } else {
> compare(sensor1, sensor2);
> Serial.println();
> void setup() {
> Serial.begin(9600);
> myservo1.attach(9); // attaches the servo on pin 9 to the servo object
> myservo_index.attach(4); //index finger
> myservo_middle.attach(5); // middle finger
> myservo_ring_small.attach(6); //small finger and ring finger
> myservo_thumb.attach(7); // thumb
> finger_position(fing_pos);
> // wait until serial port opens for native USB devices
> while (! Serial) { delay(1); }
> pinMode(SHT_LOX1, OUTPUT);
> pinMode(SHT_LOX2, OUTPUT);
> Serial.println(F("Shutdown pins inited..."));
> digitalWrite(SHT_LOX1, LOW);
> digitalWrite(SHT_LOX2, LOW);
> Serial.println(F("Both in reset mode...(pins are low)"));
> Serial.println(F("Starting..."));
> setID();
> void finger_position(int a){
> myservo_index.write(a); //index finger
> myservo_middle.write(a); // middle finger
> myservo_ring_small.write(a); //small finger and ring finger
> myservo_thumb.write(a); // thumb
> void open_close(int a, int b){
> int s1 = a;
> int s2 = b;
> Serial.println("WERE ARE IN");
> if (122 < s1 && s1 < 142){
> int pos_f = 60;
> Serial.println("60");
> finger_position(pos_f);
> if (110 < s1 && s1 <= 122){
> int pos_f = 80;
> Serial.println("80");
> if (100 < s1 && s1 <= 110){
> int pos_f = 90;
> Serial.println("90");
> if (90 < s1 && s1 <= 100){
> int pos_f = 100;
> Serial.println("100");
> if (80 < s1 && s1 <= 90){
> int pos_f = 110;
> Serial.println("110");
> if (70 < s1 && s1 <= 80){
> int pos_f = 120;
> Serial.println("120");
> if (60 < s1 && s1 <= 70){
> int pos_f = 140;
> Serial.println("140");
> if (50 < s1 && s1 <= 60){
> int pos_f = 160;
> Serial.println("160");
> void compare(int a, int b){
> // unsigned compare_currentTime = millis();
> int diff = abs(a - b);
> int sen1 = a;
> int sen2 = b;
> if (a > b){
> if (diff > 30){
> // A: Sensor 1, B: Sensor 2
> Serial.println("Sensor 1 is higher");
> if (diff <= 30){
> Serial.println("Within bounds");
> open_close(a, b);
> else if (b > a){
> if (diff > 30){
> Serial.println("Sensor 2 takes lead");
> if (diff <= 30){
> Serial.println("Within bound");
> open_close(a, b);
> void loop() {
> unsigned currentTime = millis();
> if (currentTime - startTime_display >= interval_display){
> startTime_display = currentTime;
> read_dual_sensors();
> // compare(sensor1, sensor2);
Ive attached is my circuit diagram to this question. Could you please analyze it and tell me what I'm doing wrong and how I could make my servos move faster?
Schematic_circuit_2022-07-01.pdf - Google Drive
Thank you!
