Really slow program
Any suggestions to speed this up?? (Work in progress) in runs, a bit, but real slow. (Mega 2560 if I uncomment both Serial.print() marked //////: vector error!! again!! no verbose mode warnings.)
//Real Variables
const int floors = 5;                                                    //number of floor the elevator travels to
const int functButtons = 2;                                              //numer of function buttons in the cabin (all buttons except floors)
const int menuButtons = 3;                                               //number of buttons the device contains to control the menu
//Number of LEDs
const int numLEDnum = floors + 1;                                        //real number of number LEDs
const int functLEDnum = functButtons + 1;                                //real number of function LEDs
const int menuLEDnum = menuButtons;                                      //real number of menu LEDs
//Total amount of
const int totalLEDs = numLEDnum + functLEDnum + menuLEDnum;              //Total amount of LEDs
const int totalButtons = floors + functButtons + menuButtons;            //Total amount of Buttons
//Pins assigned to Buttons
const int numButton[] = {4, 5, 6, 7, 8};                                 //pins assigned to each button in ascending order (0 to 4)
const int functButton[] = {2, 3};                                        //pins assigned to each function button in order (bottom to top)
const int menuButton[] = {9, 10, 11};                                    //pins assigned to each menu button in order
int allButtons[totalButtons];
//Pins assigned to LEDs
const int numLED[] = {27, 26, 25, 24, 23, 22};                           //LED pins ordered lowest to highest (floor 0 to 4)
const int functLED[] = {30, 29, 28};                                     //LED pins ordered bottom to top
const int menuLED[] = {33, 32, 31};                                      //LED pins ordered minus, plus, ok
int allLEDs[totalLEDs];
//Arrays for LED and Button state
boolean buttonStates[totalButtons];                                      //holds state of buttons
boolean buttonMem[totalButtons];                                         //hold last state of Buttons to compare to.
boolean LEDStates[totalLEDs];                                            //holds state of LEDs
// Variables for ButtonTranslate
String buttonName;                                                       //input var containing name and num
int length;                                                              //num of chars in buttonName
int charindex;                                                           //num of char being processed
String name;                                                             //buttonName substring containing name
int num;        //int of buttonName substring containing num
//Variables for Debounce (Button has to be pressed for a certain amount of time for press to count)
const int debounceDelay = 10;                                           //miliseconds the button has to be pressed for press to count
boolean state;                                                          //actual state of button (for debounce)
boolean previousState;                                                  //last state of button  (for debounce)
//Array for buttonRequest
boolean buttonRequest[totalButtons];                                     //holds buttons request
//Vars for SetLEDMode
boolean LEDSwitch = 1;
int followMode = 1;
//Enums
enum buttonNames {cnnumButtons, cnfunctButtons, cnmenuButtons};
  Serial.begin (9600);                                                   //Start Serial connection
  //compose allLEDs[] adding numLED[], functLED[] and menuLED[] info
  for (int i = 0; i < numLEDnum; i++) {
    allLEDs[i] = numLED[i];
  for (int i = numLEDnum; i < (numLEDnum + functLEDnum); i++) {
    allLEDs[i] = functLED[i - numLEDnum];
  for (int i = (numLEDnum + functLEDnum); i < (numLEDnum + functLEDnum + menuLEDnum); i++) {
    allLEDs[i] = menuLED[i - (numLEDnum + functLEDnum)];
  //compose allButtons[] adding numButton[], functButton[] and menuButton[] info
  for (int i = 0; i < floors; i++) {
    allButtons[i] = numButton[i];
  for (int i = floors; i < (floors + functButtons); i++) {
    allButtons[i] = functButton[i - floors];
  for (int i = (floors + functButtons); i < (floors + functButtons + menuButtons); i++) {
    allButtons[i] = menuButton[i - (floors + functButtons)];
  //Declare LED pins as OUTPUT
  for (int i = 0; i < totalLEDs; i++) {                                  //Declare LEDs as OUTPUT
    pinMode(allLEDs[i], OUTPUT);
  //Declare Button pins as INPUT
  for (int i = 0; i < totalButtons; i++) {                               //Declare Buttons as INPUT
    pinMode(allButtons[i], INPUT);
 __        ______     ______   .______
|  |      /  __  \   /  __  \  |   _  \
|  |     |  |  |  | |  |  |  | |  |_)  |
|  |     |  |  |  | |  |  |  | |   ___/
|_______| \______/   \______/  | _|
  if (ButtonChange() == HIGH) {
    //***//***//Serial.println("entered");
    FollowButtons();
int WhatLED (int buttoni) {
  if (buttoni >= 0 && buttoni < floors) {
    return buttoni;
  if (buttoni >= floors && buttoni < (floors + functButtons)) {
    return (buttoni + 1);
  if (buttoni >= (floors + functButtons) && buttoni < totalButtons) {
    return (buttoni + 2);
  return -1; //error code
void LightLEDs() {
    digitalWrite(allLEDs[i], LEDStates[i]);
void FollowButtons() {
  ScanButtons();
  //***//***//Serial.println("hello");
    int startLED = WhatLED(i);
    boolean state = buttonStates[i] ;
    LEDStates[startLED] = state;
    if (i < (floors + functButtons)) {
      LEDStates[(startLED + 1)] = state;
    LightLEDs(); // (add if)
boolean debounce(int pin) {                                              //returns HIGH if button if HIGH for debounceDelay in miliseconds
  previousState = digitalRead(pin);                                      //store pin state
  for (int i = 0; i < debounceDelay; i++) {                              //make sure button is pressed every milisecond debounceDelay times
    delay(1);
    state = digitalRead(pin);
    if (state != previousState) {                                        //reset if change in state
      i = 0;
      previousState = state;
  return state;                                                          //return stable state
void ScanButtons() {                                                     //reads all buttons and stores state
    buttonStates[i] = debounce(allButtons[i]);
boolean ButtonChange() {                                                 //returns HIGH if there has been a change in button state from last scan
      buttonMem[i] = buttonStates[i];
    ScanButtons();
      if (buttonMem[i] != buttonStates[i]) {
        return HIGH;
  return LOW;
Not sure but you are debouncing all your buttons is series, at 10ms per button might take a while?
To debounce read all the buttons, wait one delay, read them all again, see if any changed - in other words debounce them in parallel.
I think MarkT is right. 10 x 10 mS debounce is 100 mS (1/10th of a second) every time you scan.
First, you only need to debounce if the state changes, second as he said, you can debounce them all at once.
I did an example here:
http://arduino.cc/forum/index.php/topic,139805.msg1053019.html#msg1053019
That shows how you can maintain a "last change" time for each switch, and debounce. Also it does not use delay at all.
That shows how you can maintain a “last change” time for each switch, and debounce. Also it does not use delay at all.
Great, thanks. Real nice.
What does this do??
(switchState [i] == LOW) ? "ON  " : "off ")
If switch state is non-zero then return "ON', else return "off"
There are many ints that can be an uint8_t that makes arrays shorter; loops faster etc as long as the range is 0…255 (e.g. pin numbers)
can be better written with two indices in the for loop. removes an subtraction every loop.
  for (uint8_t i = 0, uint8_t j = numLEDnum ; i < functLEDnum; i++, j++) {  // there is a comma , twice !!
    allLEDs[j] = functLED[i];
    return buttoni;
can be shorter
  if ( buttoni >= 0 && buttoni < floors) return buttoni;
  if ( buttoni < (floors + functButtons)) return (buttoni + 1);  // as the first test assures that buttoni >= floors
  if ( buttoni < totalButtons) return (buttoni + 2);
    ScanButtons();
        return HIGH;
  return LOW;
why not return the index of the button that is changed, is a flag and value in one
int ButtonChange()
    for (uint8_t i = 0; i < totalButtons; i++) buttonMem[i] = buttonStates[i];
    ScanButtons();
        return i;  // at least button i has changed (but there might be more)
  return -1;   // no button
your turn
oh, right.
I changed all ints to byte now. is uint8_t better or same??
same
whats the diff in size now?
RonaldPoFo:
Yeah, byte and uint8_t are both unsigned char.
