I use a RGB led on a Arduino Uno. My program lit the colors in setup during a LED test and then leave all off. This works as expected. Then in my program I lit colors depending an value from a soundsensor. When this value is between 100 and 150 the green should light up. And with a breakpoint I can conclude that this happen. But then after the program continues the green LED extinguishes. This is beyond my understanding. In the LOOP I only set LED in the SetLED function and I have set breakpoints on the lines that turn off the green led and these are never hit. But still the green is turned of. Values that should lit blue and red does so but when new data comes first the green occasionally lit up before the blue or red turns on and remains on. Full program below
#include <LiquidCrystal.h>
#include <RH_ASK.h>
#include <SPI.h>
const int RED = 9;
const int GREEN = 10;
const int BLUE = 8;
const int Gate = 13;
const int Envelope = 1;
const int Pressure = 0;
LiquidCrystal lcd(6,7,5,4,3,2);
RH_ASK rf_driver;
pinMode(Gate, INPUT);
pinMode(RED, OUTPUT); //Red
pinMode(BLUE, OUTPUT); //Blue
pinMode(GREEN, OUTPUT); //Green
pinMode(12, OUTPUT); //Radio module data
lcd.begin(16,2);
if (!rf_driver.init())
Serial.println("RF init failed");
Serial.println("RF init OK");
Serial.println("SUPERVISOR STARTED");
lcd.print("** Supervisor **");
lcd.setCursor(0, 1);
lcd.print("Test LEDS");
lcd.setCursor(10, 1);
lcd.print("RED");
digitalWrite(RED,HIGH);
delay(2900);
lcd.print("BLUE");
digitalWrite(RED,LOW);
digitalWrite(BLUE,HIGH);
delay(2900);
lcd.print("GREEN");
digitalWrite(BLUE,LOW);
digitalWrite(GREEN,HIGH);
delay(2900);
digitalWrite(GREEN,LOW);
delay(2900);
NewDisplayLCDHeaders();
unsigned long int soundLowTime = 0;
unsigned long int soundMidTime = 0;
unsigned long int soundHigTime = 0;
unsigned long int soundGTime = 0;
unsigned long int pulsetime = 0;
bool gateevent, lowevent, midevent, highevent;
bool CompletePulse = false; //With regard to threshold 50
bool soundLowFlag = false;
bool soundMidFlag = false;
bool soundHigFlag = false;
bool soundGFlag = false;
bool soundgate = false;
bool gatePulse = false;
bool lowPulse = false;
bool midPulse = false;
bool highPulse = false;
bool newData = false;
bool newsndmax = false;
bool newpulse = false;
unsigned int soundlevel;
unsigned int soundGlevel = 0; //soundlevel when active gate is detected
unsigned int soundMinGlevel = 0xFFF;//min detected soundlevel when gate triggered
unsigned int soundLowLevel = 0; //Soundlevel when low soundlevel detected
unsigned int soundMidLevel = 0; //Soundlevel when mid soundlevel detected
unsigned int soundHigLevel = 0; //Soundlevel when high soundlevel detected
unsigned int pdrlevel;
unsigned int soundmax;
unsigned int soundmin;
unsigned int pdrmax;
unsigned int pdrmin;
unsigned long int pdrsum;
unsigned int pdravg;
unsigned int soundGateNr = 0;
unsigned int soundLowNr = 0;
unsigned int soundMidNr = 0;
unsigned int soundHigNr = 0;
unsigned int soundPrevGateNr = 0;
unsigned int soundPrevLowNr = 0;
unsigned int soundPrevMidNr = 0;
unsigned int soundPrevHigNr = 0;
char sndlowdur[7] = " ";
char sndmiddur[7] = " ";
char sndhigdur[7] = " ";
char sndGdur[7] = " ";
char sndnr[6] = " ";
char sndgnr[6] = " ";
char sndlownr[6] = " ";
char sndmidnr[6] = " ";
char sndhignr[6] = " ";
char sndmax[5] = " ";
char sndmin[5] = " ";
char sndlev[6] = " ";
char pdrlev[6] = " ";
char sndlowlevel[5] = " ";
char sndmidlevel[5] = " ";
char sndhiglevel[5] = " ";
char prsmax[5] = " ";
char prsmin[5] = " ";
char prsavg[5] = " ";
char GateLevelString[5] = " ";
char LowLevelString[5] = " ";
char MidLevelString[5] = " ";
char HighLevelString[5] = " ";
char datastring[50];
char tempstr[10];
int MaxPulseLevel = 0;
unsigned long int MaxPulseCount = 0;
soundlevel = analogRead(Envelope);
pdrlevel = analogRead(Pressure);
soundmax=soundlevel;
soundmin=soundlevel;
pdrmax=pdrlevel;
pdrmin=pdrlevel;
gateevent = lowevent = midevent = highevent = false;
do
newData = false; // No completed soundpulse detected
soundgate = digitalRead(Gate); // Read the digitsal sound gate output
soundlevel = analogRead(Envelope); // Read the analog envelope soundlevel value
pdrlevel = analogRead(Pressure); // Read the analog pressure level
AnalyzeSoundPulse(); // With regard to threshold 50
setSoundData(); // Set Max Min values and newsndmax flag
if (newsndmax)
newsndmax = false;
SetLED(soundmax);
FillSpacesLCD(3, 0);
lcd.setCursor(3, 0);
itoa(soundmax, sndmax, 10);
lcd.print(sndmax); //Max level during whole runtime in upper left corner of LCD
setPressureData(); // Set Max Min values
GetSoundDataPulses(); // Check for below or above threshold for specific (G,L,M,H) completed soundpulses
ResetDataString();
SetDataString();
if (newData)
Serial.println(datastring);
rf_driver.send((const uint8_t *)datastring,strlen(datastring));
if (CompletePulse)
Serial.print("MaxPulseLevel=");
Serial.println(MaxPulseLevel);
DisplayPulseData();
PrintPulseCounts();
NewDisplayLCDData();
} while(true);
void PrintPulseCounts()
Serial.print("Gate count=");
Serial.println(soundGateNr);
Serial.print("Low count =");
Serial.println(soundLowNr);
Serial.print("Mid count=");
Serial.println(soundMidNr);
Serial.print("High count=");
Serial.println(soundHigNr);
void AnalyzeSoundPulse()
if (soundlevel > 50)
if (!newpulse) //If a new pulse has started
pulsetime = millis();
MaxPulseLevel = soundlevel;
newpulse = true;
if (soundlevel > MaxPulseLevel) //Track max soundlevel during pulse
else if (newpulse) //Completed pulse for threshold 50
pulsetime = millis() - pulsetime;
newpulse = false;
CompletePulse = true;
MaxPulseCount++;
void GetSoundDataPulses() //Detect max level and duration for specific (G,L,M,H) pulses and set flag for occured event
if (soundgate) //Is gate on soundsensor triggered ? Then G event
if (!soundGFlag)
soundGTime = millis(); //First time gate event active start timer
soundGlevel = soundlevel; //And store soundlevel at time when event detected
soundGFlag = true; //gate pulse started
else if (soundGFlag) //If gate no longer active but have been thus soundgate event has ended
soundGTime = millis() - soundGTime; //Calculate time in mS for soundgate event
soundGFlag = false;
gateevent = true;
soundGateNr += 1; //Count up number of this pulse event has occured
if (soundlevel >= 100) //Low L event
if (!soundLowFlag)
soundLowTime = millis();
soundLowLevel = soundlevel;
soundLowFlag = true;
if (soundlevel > soundLowLevel)
else if (soundLowFlag) //Have been over soundlevel threshold
soundLowTime = millis() - soundLowTime;
lowevent = true;
soundLowNr += 1;
if (soundlevel >= 150)
if (!soundMidFlag)
soundMidTime = millis();
soundMidLevel = soundlevel;
soundMidFlag = true;
if (soundlevel > soundMidLevel)
else if (soundMidFlag) //Have been over soundlevel threshold
soundMidTime = millis() - soundMidTime;
midevent = true;
soundMidNr += 1;
if (soundlevel >= 250)
if (!soundHigFlag)
soundHigTime = millis();
soundHigLevel = soundlevel;
soundHigFlag = true;
if (soundlevel > soundHigLevel)
else if (soundHigFlag) //Have been over soundlevel threshold
soundHigTime = millis() - soundHigTime;
highevent = true;
soundHigNr += 1;
void SetDataString()
if (soundGateNr > soundPrevGateNr) //Check if new sound pulses (has it raised above and then back to below threshold?)
gatePulse = true; //Gate pulse has happened
soundPrevGateNr = soundGateNr;
itoa(soundGateNr, sndgnr, 10);
datastring[0] = 'G';
strcat(datastring, sndgnr);
itoa(soundGTime, sndGdur, 10);
datastring[strlen(datastring)] = 'D';
strcat(datastring, sndGdur);
datastring[strlen(datastring)] = 'N';
itoa(soundGlevel, sndlev, 10);
strcat(datastring, sndlev);
itoa(soundGlevel, GateLevelString, 10);
newData = true;
if (soundLowNr > soundPrevLowNr)
lowPulse = true; //Low pulse has happened
soundPrevLowNr = soundLowNr;
itoa(soundLowNr, sndlownr, 10);
if (gateevent)
datastring[strlen(datastring)] = 'L';
datastring[0] = 'L';
strcat(datastring, sndlownr);
itoa(soundLowTime, sndlowdur, 10);
strcat(datastring, sndlowdur);
itoa(soundLowLevel, sndlev, 10);
itoa(soundLowLevel, LowLevelString, 10);
newData = true;
if (soundMidNr > soundPrevMidNr)
midPulse = true; //Mid pulse has happened
soundPrevMidNr = soundMidNr;
itoa(soundMidNr, sndmidnr, 10);
if (lowevent)
datastring[strlen(datastring)] = 'M';
datastring[0] = 'M';
strcat(datastring, sndmidnr);
itoa(soundMidTime, sndmiddur, 10);
strcat(datastring, sndmiddur);
itoa(soundMidLevel, sndlev, 10);
itoa(soundMidLevel, MidLevelString, 10);
newData = true;
if (soundHigNr > soundPrevHigNr)
highPulse = true; //High pulse has happened
soundPrevHigNr = soundHigNr;
itoa(soundHigNr, sndhignr, 10);
if (midevent)
datastring[strlen(datastring)] = 'H';
datastring[0] = 'H'; //Start datastring with H indicating high level sound pulse
strcat(datastring, sndhignr); //Add current numbers of high pulses to datastring
itoa(soundHigTime, sndhigdur, 10); //Convert current high pulse duration to string
datastring[strlen(datastring)] = 'D'; //First add D to datastring to indicate duration
strcat(datastring, sndhigdur); //Then add the value of the duration to datastring
datastring[strlen(datastring)] = 'N'; //Add N (for Nivå) till datastring
itoa(soundlevel, sndlev, 10); //Convert soundlevel to string
strcat(datastring, sndlev); //And add that string to datastring
itoa(soundHigLevel, HighLevelString, 10);
newData = true;
void DisplayPulseData() //Display pulse flag in upper right part of LCD
if (MaxPulseLevel<100)
lcd.setCursor(9, 0);
lcd.print("G");
lcd.setCursor(11, 0);
itoa(MaxPulseLevel, sndlev, 10);
lcd.print(sndlev);
if (MaxPulseLevel>=100 && MaxPulseLevel<150)
lcd.print("L");
lcd.print(sndlev);
if (MaxPulseLevel >= 150 && MaxPulseLevel < 250)
lcd.print("M");
lcd.print(sndlev);
if (MaxPulseLevel >= 250)
lcd.print("H");
lcd.print(sndlev);
MaxPulseLevel = 0;
void NewDisplayLCDData() //Display duration for specific (G,L,M,H) pulse
if (highPulse)
highPulse = false;
FillSpacesLCD(2,1);
lcd.setCursor(2, 1);
lcd.print(sndhigdur);
lcd.setCursor(15, 1);
lcd.print("H");
highevent = false;
else if (midPulse)
midPulse = false;
FillSpacesLCD(2,1);
lcd.print(sndmiddur);
lcd.setCursor(14, 1);
lcd.print("M"); //Indicate that mid pulse has occured
midevent = false;
else if (lowPulse)
lowPulse = false;
FillSpacesLCD(2,1);
lcd.print(sndlowdur);
lcd.setCursor(13, 1);
lcd.print("L"); //Indicate that low pulse has occured
lowevent = false;
else if (gatePulse)
gatePulse = false;
lcd.print("G");
FillSpacesLCD(11,0);
lcd.print(GateLevelString);
lcd.print(sndGdur);
lcd.setCursor(12, 1);
lcd.print("G"); //Indicate that gate pulse has occured
gateevent = false;
void NewDisplayLCDHeaders()
lcd.setCursor(0, 0);
lcd.print("LM= L = ");
lcd.print("D= ");
void SetLED(int max)
Serial.print("SetLED max=");
Serial.println(max);
if (max>=100 && max<150)
Serial.println("Light GREEN");
digitalWrite(BLUE, LOW);
digitalWrite(GREEN, HIGH);
digitalWrite(RED, LOW);
if (max>=150 && max<250)
Serial.println("Light BLUE");
digitalWrite(BLUE, HIGH);
digitalWrite(GREEN, LOW);
if (max>=250)
Serial.println("Light RED");
digitalWrite(RED, HIGH);
void setPressureData()
if (pdrlevel > pdrmax)
pdrmax = pdrlevel;
if (pdrlevel < pdrmin)
pdrmin = pdrlevel;
void setPdrDataString()
itoa(pdravg, pdrlev, 10);
strcat(datastring, pdrlev);
datastring[strlen(datastring)] = ' ';
itoa(pdrmin, pdrlev, 10);
itoa(pdrmax, pdrlev, 10);
void setSoundData()
if (soundlevel > soundmax)
soundmax = soundlevel;
newsndmax = true;
if (soundlevel<soundmin)
void ResetDataString()
for (int i = 0; i < 50; i++)
datastring[i] = '\0';
void FillSpacesLCD(int col,int row)
lcd.setCursor(col, row);
lcd.print(" ");
