Really strange local variable problem
I am using an Arduino Yun with an external RS232 card and SoftwareSerial library.
My problem is if I declare a local variable k as a counter in loop(), it never increments!!! However if I declare it as a global variable it works fine.
Here is the code:
#include <SoftwareSerial.h>
SoftwareSerial mySerial(10, 5); // RX, TX
int k = 0;
  while(!Serial);
  Serial.println("OK");
  // start the external RS232 driver
  mySerial.begin(9600);
  char command[100];
//  int k = 0;
  if (mySerial.available()) {
    char c;
    Serial.println("char available");
    c = mySerial.read();
    if ((c != '\n') && (c != '\r')) {
       command[k++] = c;
       Serial.println(k);
    } else if (c == '\r') {
       // ignore
    } else if (c == '\n') {
       command[k] = '\0';
       Serial.print("\n\rGot command: ");
       Serial.println(command);
       k = 0;
  delay(50);
Here is the output with k as a local variable when I enter “abc” on the serial line:
OK
char available
1
char available
1
char available
1
char available
char available
Got command:
and with k as a global variable (as in the code above):
OK
char available
1
char available
2
char available
3
char available
char available
Got command: abc
I’m really not sure why this is? Any ideas?
Thanks.
If you declare and set k to zero every time through loop() why would you be surprised that once incremented it would not go back to zero when declared and set to zero again next time round ?
Solutions
1 Use a global variable and do not declare it in loop()
2 Declare it as static in loop() so that it retains its value if it is changed within loop()
While you are making changes either way declare it as a byte rather than an int to save memory.
       command[k++] = c;
       Serial.println(k);
       // ignore
       command[k] = '\0';
       k = 0;
You are testing for \n and \r twice.
How about:
   if (c == '\r') {
       // ignore
       command[k] = '\0';
       k = 0;
    command[k++] = c;
    Serial.println(k);
I understand now, thank you for your help. I had mis-interpreted how the loop() function works, I thought it was only called once from setup() then looped internally...I am new to Arduino so still learning.
I will use your suggestion.
Thanks again.
