ok so im a noob but i feel i really shouldn't be getting stuck on this.
this is a pretty basic controller that turns lights off and on in my shed. it will get more complicated once the basic stuff is working.
currently nothing is happening though
- iv run a test program on it that turns all the relays and leds on and off and that works
- the input pins are definitely getting 5v when i press the buton
- the relays turn on when the ttl to them is low.
- iv set one off the leds to turn on and off at different points in the code. and it flashes so i can see its running through the code
- the relays 1-3 are on
- the other led is set to turn on to show when the lights are on, i cant get this led to light up
any help is great as iv really been scratching my head on this one
// FILE: shed_basic
// AUTHOR: Josh Sams
// VERSION: 0.1.00
// PURPOSE: shed lighting control, mk2 test file
// DATE:03/06/2014
// COPYRIGHT: Released to the public domain for non profit use only. (copyright: JCStech 2014)
#define RELAY4 6 //pin to turn on -----
#define RELAY3 7 //pin to turn on side light
#define RELAY2 8 //pin to turn on door light
#define RELAY1 9 //pin to turn on interior lights
#define PUSH 11 //pin to read push button outside
#define GREEN 10 //pin to read green push button on elcosure
#define WHITE 12 //pin to read white push button on elcosure
#define LDR A2 //pin to sense outdoor light
#define LED1 2 //pin to light 1st led
#define LED2 3 //pin to light 2nd led
int val = 0;
unsigned long TIME;
pinMode(RELAY1, OUTPUT);
pinMode(RELAY2, OUTPUT);
pinMode(RELAY3, OUTPUT);
pinMode(RELAY4, OUTPUT);
pinMode(LED1, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(PUSH, INPUT);
pinMode(GREEN, INPUT);
pinMode(WHITE, INPUT);
pinMode(LDR, INPUT);
void loop(){
digitalWrite(LED1, HIGH);
if(GREEN == HIGH){
digitalWrite(RELAY1, LOW);
delay(600);
digitalWrite(RELAY2, LOW);
delay(600);
digitalWrite(RELAY3, LOW);
digitalWrite(LED2, HIGH);
if(PUSH == HIGH){
delay(600);
delay(4000);
delay(300);
if(WHITE == HIGH) {
digitalWrite(RELAY1, HIGH);
delay(15000);
digitalWrite(RELAY2, HIGH);
digitalWrite(RELAY3, HIGH);
digitalWrite(LED2, LOW);
digitalWrite(LED1, LOW);
delay(300);
//END OF FILE
