I wrote a small library by subclassing the Bounce library. So I need to include the Bounce.h file in my header file, which I did. When I moved my library into its own folder below /library, the compiler could no longer find Bounce.h.
The Arduino IDE only knows to include a library (and thus tell the compiler to include the path into where it searches) when it finds it in a sketch file. The IDE searches for this using regular expressions, looking for anything like "#include <blah.h>"
Well including Bounce.h in the main sketch should not be necessary, although that's what I did to work around the problem. As to the IDE, I would think that C++ compilers preprocessor could follow the path and read the header files. There is really no way to do this?
The problem is that the idea "intelligently" tries to work out which files it needs to include. And indeed it makes a copy of your files into a temporary area (hence why you don't even need to save your sketch to compile it). Nested .h files don't seem to cut it. I've complained about this before, no response as I recall.
My suggested work-around works, that's good. It shouldn't be necessary, so maybe complain louder to the developers of the IDE.
