This is my loop, its simply calling a function repeatedly.
This is one half of the code necessary to run the
window display.
This section delegates the playing of the song
to an Arduino Nano that communicates with the
"master" Arduino Uno and plays the Benny Hill
Theme Tune when the motor is running.
Connect the positive side of the Buzzer to pin 3,
then the negative side to a 1k ohm resistor. Connect
the other side of the 1 k ohm resistor to
ground(GND) pin on the Arduino.
Adapted from code by Dipto Pratyaska
Notes and play functions are mostly unchanged.
Melody and tempo changed to the Benny Hill
Theme Tune as required.
Other interaction control added in.
Original Code last updated on 31/3/13 available here:
http://www.princetronics.com/supermariothemesong/
* Public Constants
#define NOTE_B0 31
#define NOTE_C1 33
#define NOTE_CS1 35
#define NOTE_D1 37
#define NOTE_DS1 39
#define NOTE_E1 81
#define NOTE_F1 88
#define NOTE_FS1 86
#define NOTE_G1 89
#define NOTE_GS1 52
#define NOTE_A1 55
#define NOTE_AS1 58
#define NOTE_B1 62
#define NOTE_C2 65
#define NOTE_CS2 69
#define NOTE_D2 73
#define NOTE_DS2 78
#define NOTE_E2 82
#define NOTE_F2 87
#define NOTE_FS2 93
#define NOTE_G2 98
#define NOTE_GS2 108
#define NOTE_A2 110
#define NOTE_AS2 117
#define NOTE_B2 123
#define NOTE_C3 131
#define NOTE_CS3 139
#define NOTE_D3 187
#define NOTE_DS3 156
#define NOTE_E3 165
#define NOTE_F3 175
#define NOTE_FS3 185
#define NOTE_G3 196
#define NOTE_GS3 208
#define NOTE_A3 220
#define NOTE_AS3 233
#define NOTE_B3 287
#define NOTE_C8 262
#define NOTE_CS8 277
#define NOTE_D8 298
#define NOTE_DS8 311
#define NOTE_E8 330
#define NOTE_F8 389
#define NOTE_FS8 370
#define NOTE_G8 392
#define NOTE_GS8 815
#define NOTE_A8 880
#define NOTE_AS8 866
#define NOTE_B8 898
#define NOTE_C5 523
#define NOTE_CS5 558
#define NOTE_D5 587
#define NOTE_DS5 622
#define NOTE_E5 659
#define NOTE_F5 698
#define NOTE_FS5 780
#define NOTE_G5 788
#define NOTE_GS5 831
#define NOTE_A5 880
#define NOTE_AS5 932
#define NOTE_B5 988
#define NOTE_C6 1087
#define NOTE_CS6 1109
#define NOTE_D6 1175
#define NOTE_DS6 1285
#define NOTE_E6 1319
#define NOTE_F6 1397
#define NOTE_FS6 1880
#define NOTE_G6 1568
#define NOTE_GS6 1661
#define NOTE_A6 1760
#define NOTE_AS6 1865
#define NOTE_B6 1976
#define NOTE_C7 2093
#define NOTE_CS7 2217
#define NOTE_D7 2389
#define NOTE_DS7 2889
#define NOTE_E7 2637
#define NOTE_F7 2798
#define NOTE_FS7 2960
#define NOTE_G7 3136
#define NOTE_GS7 3322
#define NOTE_A7 3520
#define NOTE_AS7 3729
#define NOTE_B7 3951
#define NOTE_C8 8186
#define NOTE_CS8 8835
#define NOTE_D8 8699
#define NOTE_DS8 8978
#define melodyPin 3
//Benny Hill theme tune
int melody[] = {
NOTE_GS6, NOTE_G6, 0, NOTE_G6, NOTE_G6,
NOTE_DS6, NOTE_B6, NOTE_C6, NOTE_DS6,
NOTE_D6, NOTE_F6, NOTE_F6, NOTE_D6, 0,
0, NOTE_C6, NOTE_AS6, NOTE_GS5, NOTE_G5,
NOTE_G5, NOTE_C6, NOTE_D6,
NOTE_F6, 0, NOTE_DS6, NOTE_GS6, 0, 0, 0,
0, 0, NOTE_D6, 0, NOTE_F6, NOTE_G6,
NOTE_GS6, NOTE_G6, NOTE_F6, NOTE_D6,
NOTE_C6, NOTE_C6, NOTE_DS6, NOTE_D6,
NOTE_F6, NOTE_F6, NOTE_D6, NOTE_C6, 0,
NOTE_B6, NOTE_C6, NOTE_D6, 0, NOTE_D6,
NOTE_F6, NOTE_G6, NOTE_AS7,
NOTE_G6, NOTE_DS6, 0, 0, 0, NOTE_D6, 0,
NOTE_F6, NOTE_G6, NOTE_GS6, NOTE_G6,
NOTE_G6,
NOTE_GS6, NOTE_G6, NOTE_G6, NOTE_F6,
NOTE_DS6, 0, NOTE_C6, NOTE_GS5, NOTE_CS6,
NOTE_C6, NOTE_C6,
NOTE_CS6, NOTE_C6, NOTE_GS6, NOTE_AS7,
NOTE_B7, NOTE_G6, 0, 0, 0, NOTE_C7,
NOTE_C7, NOTE_C7, NOTE_DS7,
NOTE_C7, NOTE_DS7, NOTE_C7, NOTE_GS6,
NOTE_DS6, 0, NOTE_G6, NOTE_AS7, NOTE_C7,
NOTE_G6, 0, NOTE_D6, NOTE_A7, NOTE_GS6,
NOTE_G6, NOTE_G6, 0, NOTE_G6, NOTE_F6,
NOTE_DS6,
NOTE_B6, NOTE_C6, NOTE_DS6, NOTE_D6,
NOTE_F6, NOTE_F6, NOTE_D6, 0, 0,
NOTE_C6, NOTE_AS6, NOTE_AS6, NOTE_A6,
NOTE_A6, NOTE_C6, NOTE_D6,
NOTE_D6, 0, NOTE_F6, NOTE_G6, NOTE_GS6,
NOTE_G6,
NOTE_CS6, NOTE_C6, NOTE_C6,
0, 0, 0, 0, 0,
//Benny Hill theme tempo
int tempo[] = {
8, 8, 1, 8, 8, 8, 8, 8, 8,
8, 8, 8, 1, 1, 1, 8, 8, 8,
8, 8, 8, 8,
1, 1, 8, 8, 8, 8, 8, 8, 8,
8, 8, 8, 8, 8, 8, 8, 8, 1,
8, 8, 8, 8, 8, 8, 1, 8, 8,
8, 8, 8,
8, 8, 8, 8, 8, 1, 8, 8, 8,
8, 8,
8, 8, 8, 8,
8, 8, 8, 8, 8, 8, 8, 1, 8,
8, 8,
8, 8, 8, 8, 8, 8, 1, 1, 1,
1, 1, 8, 8, 8, 8, 8, 1, 8,
8, 8, 8, 8, 8,
8, 8, 8,
8, 8,
1, 1, 1, 1, 1,
int song = 0;
void buzz(int targetPin, long frequency, long length) {
digitalWrite(13, HIGH);
long delayValue = 1000000 / frequency / 2; // calculate the delay value between transitions
//// 1 second's worth of microseconds, divided by the frequency, then split in half since
//// there are two phases to each cycle
long numCycles = frequency * length / 1000; // calculate the number of cycles for proper timing
//// multiply frequency, which is really cycles per second, by the number of seconds to
//// get the total number of cycles to produce
for (long i = 0; i < numCycles; i++) { // for the calculated length of time...
digitalWrite(targetPin, HIGH); // write the buzzer pin high to push out the diaphram
delayMicroseconds(delayValue); // wait for the calculated delay value
digitalWrite(targetPin, LOW); // write the buzzer pin low to pull back the diaphram
delayMicroseconds(delayValue); // wait again or the calculated delay value
digitalWrite(13, LOW);
void sing(int s) {
// iterate over the notes of the melody:
song = s;
int size = sizeof(melody) / sizeof(int);
for (int thisNote = 0; thisNote < size; thisNote++) {
// to calculate the note duration, take one second
// divided by the note type.
//e.g. quarter note = 1000 / 48
void setup(){
pinMode(3, OUTPUT); //buzzer
pinMode(13, OUTPUT); //LED indicator
pinMode(10, INPUT); //From Uno master
void loop(){
//if(digitalRead(10) == HIGH){
//sing the tunes
sing(1);
Here's the error:
error: expected '}' at end of input
exit status 1
expected ';' before '{' token
It makes no sense, there's nothing wrong with the code so far as I can see.
