hi every body ! i found a source code to use RTC DS1307 and display time on LCD1602. When i upload code to arduino. The time on LCD is correct. But when i unplug USB cable and then plug it to computer again. the time is not correct. Please help me correct it ! Thanks
here is my code :
RTC is licensed under a Creative Commons Attribution-ShareAlike 3.0 Unported License.
*/ #include <Wire.h> #include <LiquidCrystal.h> #include <RTClib.h>
RTC_Millis RTC; //New DS1307 RTC
LiquidCrystal LCD(3,4,5,6,7,8); //New Liquid Crystal Display
int backlightOut = 9; //LCD backlight pin
int backlightIn = 2; //
unsigned long backlightTiming; //backlight ON timing (millis())
byte backlightState;
void setup(){
RTC.begin(DateTime(DATE,TIME)); //Start RTC
Wire.begin(); //Start Serial
LCD.begin(2,16); //Start LCD
LCD.clear(); //Clear LCD just in case
pinMode(backlightOut,OUTPUT); //LCD backlight
//pinMode(backlightIn,INPUT_PULLUP); //LCD backlight trigger switch signal input pin
//digitalWrite(backlightOut,HIGH); //Turn on backlight on start
void loop(){
backlightTiming = millis(); //Backlight timing
backlightState = digitalRead(backlightIn); // Read the LCD backlight trigger switch signal input pin
if(backlightTiming >= 3000){
digitalWrite(backlightOut,LOW); //Turn LCD backlight off if 3 seconds (3000 milliseconds) has passed since the start of the code
if(backlightState == 1){
digitalWrite(backlightOut,HIGH); //Turn LCD backlight on on tilt (for tilt switches (poorman's gyroscope))
DateTime now = RTC.now(); //update the DS1307's time (you should do this every year; at least)
//Time - Screen position filtering
if (now.month() < 10 && now.day() < 10){
LCD.setCursor(4,0);
else {
LCD.setCursor(3,0);
LCD.print(now.day());
LCD.print("/");
LCD.print(now.month());
LCD.print("/");
LCD.print(now.year());
LCD.print(" ");
if (now.hour() < 10 && now. minute() < 10){
LCD.setCursor(5,1);
else if (now.hour() < 10 && now.second() < 10){
LCD.setCursor(5,1);
else if (now.second() < 10 && now. minute() < 10){
LCD.setCursor(5,1);
else if (now.hour() < 10 && now. minute() < 10 && now.second() < 10){
LCD.setCursor(5,1);
else {
LCD.setCursor(4,1);
LCD.print(now.hour());
LCD.print(':');
LCD.print(now.minute());
LCD.print(':');
LCD.print(now.second());
delay(33.33); //30 fps
LCD.clear(); //update screen
vudiepdh1:
I think arduino didn't write time parameter to ds1307 ! :~
Who would know? Your battery could be dead but I think the programme is junk. A comment lines says it updates the DS1307 each and every upload and, if that is the case, it seems you might as well look at your watch and use the millis counter.
Here is one to set the clock
//Arduino 1.0+ Only
//Arduino 1.0+ Only
// pre-set the time in the void then use reset button to set it!
#include "Wire.h"
#define DS1307_ADDRESS 0x68
byte zero = 0x00; //workaround for issue #527
void setup(){
Wire.begin();
setDateTime(); //MUST CONFIGURE IN FUNCTION
void loop(){
printDate();
void setDateTime(){
byte second = 0; //0-59
byte minute = 59; //0-59
byte hour = 11; //0-23
byte weekDay = 2; //1-7 1=Monday
byte monthDay = 9; //1-31
byte month = 4; //1-12
byte year = 13; //0-99
Wire.beginTransmission(DS1307_ADDRESS);
Wire.write(zero); //stop Oscillator
Wire.write(decToBcd(second));
Wire.write(decToBcd(minute));
Wire.write(decToBcd(hour));
Wire.write(decToBcd(weekDay));
Wire.write(decToBcd(monthDay));
Wire.write(decToBcd(month));
Wire.write(decToBcd(year));
Wire.write(zero); //start
Wire.endTransmission();
byte decToBcd(byte val){
// Convert normal decimal numbers to binary coded decimal
return ( (val/10*16) + (val%10) );
byte bcdToDec(byte val) {
// Convert binary coded decimal to normal decimal numbers
return ( (val/16*10) + (val%16) );
void printDate(){
// Reset the register pointer
Wire.write(zero);
Wire.requestFrom(DS1307_ADDRESS, 7);
int second = bcdToDec(Wire.read());
int minute = bcdToDec(Wire.read());
int hour = bcdToDec(Wire.read() & 0b111111); //24 hour time
int weekDay = bcdToDec(Wire.read()); //0-6 -> sunday - Saturday
int monthDay = bcdToDec(Wire.read());
int month = bcdToDec(Wire.read());
int year = bcdToDec(Wire.read());
//print the date EG 3/1/11 23:59:59
Serial.print(month);
Serial.print("/");
Serial.print(monthDay);
Serial.print("/");
Serial.print(year);
Serial.print(" ");
Serial.print(hour);
Serial.print(":");
Serial.print(minute);
Serial.print(":");
Serial.println(second);
And here is a clock that works, use your own LCD pin setup
//Arduino 1.0+ Only
//Arduino 1.0+ Only
#include "Wire.h"
LiquidCrystal lcd(8,9,16,5,6,7);
void setup(){
Wire.begin();
lcd.begin(16, 2);
lcd.clear();
// Print a message to the LCD.
lcd.print("It is");
void loop(){
printDate();
void printDate(){
byte zero = 0x00;
Wire.write(zero);
lcd.setCursor(2, 1);
switch (weekDay) // Friendly printout the weekday
case 1:
lcd.print("MON ");
Serial.print("MON ");
case 2:
lcd.print("TUE ");
Serial.print("TUE ");
case 3:
lcd.print("WED ");
Serial.print("WED ");
case 4:
lcd.print("THU ");
Serial.print("THU ");
case 5:
lcd.print("FRI ");
Serial.print("FRI ");
case 6:
lcd.print("SAT ");
Serial.print("SAT ");
case 7:
lcd.print("SUN ");
Serial.print("SUN ");
Serial.print("/");
Serial.print("/");
Serial.print(year);
Serial.print(" ");
Serial.print(hour);
Serial.print(":");
Serial.print(":");
lcd.setCursor(8,1);
lcd.print(monthDay);
lcd.print("/");
lcd.print(month);
lcd.print("/");
lcd.print(year);
lcd.setCursor(8,0);
lcd.print(hour);
lcd.print(":");
lcd.print(minute);
lcd.print(":");
lcd.print(second);
lcd.println(" ");
