Rearrange pins for motorshield?
Hi !
I want to rearrange so that the dir A, B and PWM B are moved to 2 ,4 and 7.
i see that there are holes in the board that looks like you can rearrange them ?
Please help me, i need pin 11-13 for another board.
If you just want to move the pins about, you could either connect the shield using wires instead of directly plugging it in to the headers, or you could use an 'inbetween' shield like the one from Mayhew Labs to re-map the pins. Note that changing the other shield to avoid the clash, or getting a different motor shield or a separate motor driver board might work out cheaper and would certainly be more compact than using the inbetween shield.
so i can just use wires from 13 (motorshield) to D2 on the arduino uno ?
