I am using a non-inverting operational amplifier configuration to scale the 3.3V output from an ESP32 with a gain of 1.5.
As a result, I can obtain a voltage range of 0-5V from the original esp 0-3.3V after the operation of the op-amp. When I measure it with a voltmeter, it works perfectly.
I need to control the motor via the signal wire from the controller.
However, I've encountered an issue where the op-amps appear to burn out, though I'm not sure exactly when this happens.
I suspect it occurs when I disconnect power from the controller and then restore power (cut 42v battery and restore battery connection with controller)
i tried using lmv358 also using mcp6002 but they behave the same way
GND is same as controller and 5v i get from controller, because controller has 3 wires for using potentiometer: GND, 5V, signal
Any chance of drawing a diagram that shows the individual op amps in that package?
Like triangles with + & - inputs, an output and a power and ground for the package.
Likewise your power supply side is very vague.
First impressions is that you can't use a potential divider as a power supply for other parts as the voltage out will depend on the current draw. You need to use a voltage regulator.
Operation amplifiers need a signal ground that Is half way between the two power rails of the package, and I don't see that at all on your drawing.
Most probably your actual wiring is different from the schematic...
If you soldered it: check with a magnifying glass...
And please: keep 5V at top and gnd at bottom...
