I removed tiny (15mm x 3mm) speaker from my (not working) cordless phone and it's gives me resistance of 167 ohm.
Is it reasonable at all?
YES. Could be. If its a very small speaker
A phone speaker is held flat to the ear, it doesn't need to be powerful.
MarkT:
It does if it provides a "Loudspeaker" function or is used as the ringer; they are really noisy!
Albeit some mobile phones have a second speaker (usually on the back) for those functions.
Even so, 167 ohms is surprisingly high - most "bud" earphones are 30 ohms.
This is or was a cordless phone, not a mobile, eh?
Yes, I removed it from ear part of handset on cordless phone.
Is there any simple way to test or verify this ear piece speaker?
I agree. Could this be a magnetic non-speaker transducer? Some (many?) phones are designed to "work with hearing aids", which means that they somehow simulate the old-style phone earphones WRT magnetics. (or it could be a special speaker specifically designed for such compatibility.)
http://transition.fcc.gov/Bureaus/Common_Carrier/FAQ/faq_hac.html
flash_os:
Yes, measure the resistance - if its shorted or open its broken, otherwise
it probably works fine...
flash_os:
You already verified it.
Anything other than zero or infinite Ohms means it's probably working.
MarkT:
I was kind of assuming that saying "it's gives me resistance of 167 ohm" indicates that was in fact, the measurement on the multimeter. It's not a usual specification.
It should click when you touch the meter prods to the terminals.
Paul__B:
That, too.
(Or use a battery...)
Paul__B:
MarkT:
it probably works fine...I was kind of assuming that saying "it's gives me resistance of 167 ohm" indicates that was in fact, the measurement on the multimeter. It's not a usual specification.
You missed the implicit smiley ![]()
MarkT:
Apparently.
Incidentally, checking the resistance does not demonstrate functionality if the voice coil is glued in the gap.
