Hello,
I was trying to change the keys and access bits on a sector and then reauthenticate on that sector. For some reason, it doesn't seem to work.
The current keyA is : { 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA }
The current keyB is : { 0xBB, 0xBB, 0xBB, 0xBB, 0xBB, 0xBB }
The accessBits are: { 0x08, ox77, 0x8F }
While the User Bit is set random (I think it's 92 at the moment).
The issue is that, if I'm authenticated using a key, and I try to authenticate using another, it fails.
Also, it fails to re-authenticate after a failed authentication. I'll post the code below with some comments:
#include <SPI.h>
#include <MFRC522.h>
#define RST_PIN 9 // Configurable, see typical pin layout above
#define SS_PIN 53 // Configurable, see typical pin layout above
MFRC522 mfrc522(SS_PIN, RST_PIN); // Create MFRC522 instance
MFRC522::MIFARE_Key key;
Serial.begin(115200); // Initialize serial communications with the PC
while (!Serial); // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
SPI.begin(); // Init SPI bus
mfrc522.PCD_Init(); // Init MFRC522
if ( ! mfrc522.PCD_PerformSelfTest() )
Serial.println("Self test failed");
else Serial.println("Self test passed");
mfrc522.PCD_Init();
delay(4); // Optional delay. Some board do need more time after init to be ready, see Readme
mfrc522.PCD_DumpVersionToSerial(); // Show details of PCD - MFRC522 Card Reader details
Serial.println(F("Scan PICC to see UID, SAK, type, and data blocks..."));
// Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.
if ( ! mfrc522.PICC_IsNewCardPresent())
return;
// Select one of the cards
if ( ! mfrc522.PICC_ReadCardSerial())
return;
for (byte i = 0; i < 6; i++)
key.keyByte[i] = 0xAb;
byte sectorTrailer = 15;
MFRC522::StatusCode status;
status = (MFRC522::StatusCode) mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, sectorTrailer, &key, &(mfrc522.uid));
if (status != MFRC522::STATUS_OK) {
Serial.print("Failed to auth with key: "); dumpByteArray(key.keyByte, 6); Serial.println();
Serial.print("Auth good with: ");
mfrc522.PCD_StopCrypto1();
mfrc522.PICC_HaltA();
//mfrc522.PCD_Init();
//mfrc522.PCD_StopCrypto1();
key.keyByte[i] = 0xAA;
// Function used to dump an array of bytes
void dumpByteArray(byte *buffer, byte bufferSize) {
for (byte i = 0; i < bufferSize; i++) {
Serial.print(buffer[i] < 0x10 ? " 0" : " ");
Serial.print(buffer[i], HEX);
So, after I try to authenticate with a wrong key, I can't get to auth with the right one, even after calling PCD_StopCrypto1() or PICC_HaltA();
Please shed some light no what's going on.
Thank you.
