Reboot issue with Modbus RTU - PLC IDE
I have set up a VFD to receive Modbus commands from the PLC.
There is a tutorial doc for setting up a new RS-485 channel and object, but that doesn't seem to be where the issue comes from.
In short, I used a sysMbMRtu_FC06 function block as a Modbus function code 06 to write a single register corresponding to address 42331 (the VFD's speed input address).
This is run in a background program (MB_Task set as background program) as per the function block description.
When I download the code, it hangs up at 'Waiting for target to reboot'.
I can successfully escape the freeze by hitting the RST and then going back online.
I can open a simple program and download a ladder, no problem. The freezing is only when I add the Modbus function blocks (still stuck after about 10 mins, so something is definitely wrong with the reboot).
Can only do one image per post, so here is the RS-485 setup with the Modbus params.
And then finally, here is the function block used in the background program, along with its description.
FB_Desc
Here is my next path forward for using RS-485, but perhaps someone could verify if this is indeed the problem?
Does the RS-485 TX/RX share pins with the USB connection? In other words, as soon as I enable the RS-485, I immediately disable my USB connection to the computer?
I can't identify the exact pin designations from the pinout to determine if these use the same pins from the controller, but I have backed up a few steps, and the freezing occurs directly at the end of the download when I switch the RS-485 from 'disabled' to 'Modbus TCP'.
My next attempt will be programming the PMC over Ethernet.
