Recalibration of Anolog input
I am trying to get a reading from a potentiometer(0-5000) on the serial monitor and then be able to zero and recalibrate at different points with an IR remote at different points(say the value is 2000, I need to make that 0 if I hit a button and go from there). Thank you in advance, any help is much appreciated!
Here is my code so far(I have added and deleted much)
#include <IRremote.h> // use the library
const int analogInPin = A0; // Analog input pin that the potentiometer is attached to
const int analogOutPin = 9; // Analog output pin that the LED is attached to
int sensorValue = 0; // value read from the pot
int outputValue = 0; // value output to the PWM (analog out)
int receiver = 11;
IRrecv irrecv(receiver); // create instance of 'irrecv'
decode_results results;
// initialize serial communications at 9600 bps:
irrecv.enableIRIn(); // Start the receiver
// read the analog in value:
sensorValue = analogRead(analogInPin);
// map it to the range of the analog out:
sVal();
// change the analog out value:
analogWrite(analogOutPin, outputValue);
// print the results to the serial monitor:
Serial.print("sensor = " );
Serial.print(sensorValue);
Serial.print("\t output = ");
Serial.println(outputValue);
// for the analog-to-digital converter to settle
// after the last reading:
delay(300);
void sVal()
outputValue = map(sensorValue, 0, 1023, 0, 5000);
What????
  1. You can't get 2000 from the analog-to-digital converter. It goes 0-1023.
  2. Check your map function.. Your map() function maps zero to zero.
Maybe you want another map() function to map from 0-5000 to 2000- ...something??? Or, to re-map your orginal values from 0-1023 values to 2000- ....something.
carlislew:
Ok, you have our permission...
..or did you have an actual question?
Why not just multiply it by 5?
sensorValue = 5*(analogRead(analogInPin));
and skip the mapping.
Result will be 0,5,10,15,20 ... 5100, 5105, 5110, 5115
I actually have it working when mapped 0-5000. It's when I try to zero and recalibrate with remote to digital input that I cannot get it to work. I have tried creating new methods to use a new map with different values when zeroed but to no avail. So my question is, how do I get a button press on an IR remote to zero the readout and recalibrate?
CrossRoads:
I just assume I will have no idea what value the sensorValue will be when I zero it, but whatever it is I need to make that zero and the values go up from there when a button is pushed on an IR remote.
So when the button is pressed you take a reading and use that reading as the minimum point in your new map function.
Or you can use that reading to subtract from subsequent readings.
DVDdoug:
What????
I have it mapped 0-5000 now and it works when I change value on the pot. I just need to be able to make whatever value that is zero when I get input from a remote and then recalibrate. I would compare it to the tare on a scale so that when a bag is on the scale the weight is not actually 0 but it starts at 0 and the weight added is what it reads.
Yes but you don't get all the numbers from 0 to 5000 they will go up in jumps of 5 or so.
What was wrong with my last answer?
Grumpy_Mike:
I think you had a good answer, I am kind of to that point. I am just having trouble with getting that part in motion. When I set a variable to equal the value at the zero point, I end up going in circles trying to get it to work. Usually I just get a constant zero reading and go back and forth changing things around until it ends up a mess and start all over.
