REceive ir and send an other
Hello,
does anyone knows a sketch to receive a remote control code and send a other remote control code.
My Hardware is Arduino Uno . A Notebook with Windows 11 installed and also Arduino Ide 2.3.5
The Ir to send is connect to Pin 3 (anode) ( Digital PWM ) and Ground.
The Ir to receive is connect to Pin 2 and also to 5 Volt and Ground.
Example :
Received Code :
unsigned int raw[26] = {900,850,950,850,1800,850,900,850,950,800,950,850,900,850,950,800,950,850,900,850,950,800,950,1700,900,};
irsend.sendRaw(raw,26,38);
Code to be sending :
unsigned int raw[24] = {900,850,950,800,1850,800,950,850,900,850,950,800,950,1700,1850,850,900,850,950,800,950,1700,850,};
irsend.sendRaw(raw,24,38);
I think it will be something like if ... then ... in a loop.
But im to stupid :-/
Install the latest IRremote library 4.4.1 and use example sketch from there.
You need current limiting resistor in series.
