We are using Arduino UNO and a SIM900 GSM Module. We figured out how to send a message from the module to a phone. We are unable to figure out which AT commands to use to recevie a message and read it. We used the standard Rx and Tx pins and did not use the SoftwareSerial library. Can someone please help us out?
Example code availble in gsm library:
you need to download IDE v1.5.8 or greater than that for windows platform. code is as below
#include <GSM.h>
#define PINNUMBER ""
// initialize the library instance
GSM gsmAccess;
GSM_SMS sms;
// initialize serial communications and wait for port to open:
while (!Serial) {
; // wait for serial port to connect. Needed for Leonardo only
Serial.println("SMS Messages Sender");
// connection state
boolean notConnected = true;
// Start GSM shield
// If your SIM has PIN, pass it as a parameter of begin() in quotes
while(notConnected)
if(gsmAccess.begin(PINNUMBER)==GSM_READY)
notConnected = false;
Serial.println("Not connected");
Serial.println("GSM initialized");
Serial.print("Enter a mobile number: ");
char remoteNum[20]; // telephone number to send sms
readSerial(remoteNum);
Serial.println(remoteNum);
// sms text
Serial.print("Now, enter SMS content: ");
char txtMsg[200];
readSerial(txtMsg);
Serial.println("SENDING");
Serial.println("Message:");
Serial.println(txtMsg);
// send the message
sms.beginSMS(remoteNum);
sms.print(txtMsg);
sms.endSMS();
Serial.println("\nCOMPLETE!\n");
Read input serial
int readSerial(char result[])
int i = 0;
while(1)
while (Serial.available() > 0)
char inChar = Serial.read();
if (inChar == '\n')
result[i] = '\0';
Serial.flush();
return 0;
if(inChar!='\r')
result[i] = inChar;
i++;
That seems to be a sender. This is a receiver I have. I assume it came with the GSM library
#include <GSM.h>
GSM gsmAccess;
GSM_SMS sms;
char senderNumber[20];
int led=13;
pinMode(led,OUTPUT);
digitalWrite(led,LOW);
while (!Serial) {
Serial.println("SMS Messages Receiver");
while(notConnected)
if(gsmAccess.begin("6442")==GSM_READY)
Serial.println("Waiting for messages");
char c;
int val=0;
val=digitalRead(led);
if (val==HIGH){
digitalWrite(led,HIGH);
if (sms.available())
Serial.println("Message received from:");
sms.remoteNumber(senderNumber, 20);
Serial.println(senderNumber);
if(sms.peek()=='#')
Serial.println("Discarded SMS");
sms.flush();
while(c=sms.read())
if(c='off'){
}else{
Serial.print(c);
Serial.println("\nEND OF MESSAGE");
sms.flush();
Serial.println("MESSAGE DELETED");
Simple answer...
You poll the GSM modem for any received messages the simplest poll os
AT + CMGL = ALL
The answer will be a responce of the form
CMGL: N where N = number of messages then you get message body..
The list terminates with an OK and a carriage return line feed
If there are no messages the responce to the Poll is simply OK carriage return Line feed.
