I'm trying to use an Arduino Nano to communicate with a Quectel EC25 module from this Raspberry Pi 4G HAT. I'm using Arduino's pins 8 and 7 to communicate with RX and TX from the Quectel module. I'm able to establish communication and send AT commands.
The problem is that when I start to listen for incoming SMS, the available() method does not change status, even if an SMS is received. This is the code I'm using:
#include <SoftwareSerial.h>
#define DEBUG Serial
SoftwareSerial EC25(8,7); // RX, TX - 9600 baud rate
#define AT_RESPONSE_LEN 100
#define TIMEOUT 1000
EC25.begin(9600);
DEBUG.begin(9600);
sendATComm("ATE1","OK\r\n");
sendATComm("AT","OK\r\n");
sendATComm("AT+IPR?","OK\r\n");
sendATComm("AT+CGSN","OK\r\n");
sendATComm("AT+CNMI=2,1","OK\r\n");
DEBUG.println("listennig");
if (EC25.available()){
DEBUG.println("Available");
// function for sending at command.
const char* sendATComm(const char *command, const char *desired_reponse)
uint32_t timer;
char response[AT_RESPONSE_LEN]; // module response for AT commands.
memset(response, 0 , AT_RESPONSE_LEN);
EC25.flush();
sendATCommOnce(command);
timer = millis();
while(true){
if(millis()-timer > TIMEOUT){
timer = millis();
char c;
int i = 0;
while(EC25.available()){
c = EC25.read();
DEBUG.write(c);
response[i++]=c;
delay(2);
if(strstr(response, desired_reponse)){
return response;
memset(response, 0 , strlen(response));
// send at comamand to module
void sendATCommOnce(const char *comm)
EC25.print(comm);
EC25.print("\r");
That gives the following output:
ATE1
OK
AT
OK
AT+IPR?
+IPR: 9600
OK
AT+CGSN
860548040717545
OK
AT+CNMI=2,1
OK
listening
I also tried with GSM library by changing the default RX and TX pins but I don't get any response.
