Received Data from nRF24L01
Hello ,
Iam sending text “red” from one board to another that is working. i received the text “red”. Then will i make an “If” request “if the text is red” but the programm dont jump into the “if” function . Can everyone help me??
Code seems incomplete.
What does red(); do?
Johnny010:
red switch on Led stripe red
The == operator does not compare array content; it compares for equality of the two addresses. You should use the function strcmp(). Google is your friend.
Also, you need to look at the documentation for radio.read(); I suspect you are using it wrongly.
Use strncmp() over strcmp(). It's faster and safer if a C string isn't null terminated.
OR better yet, use a string library for micro-controllers. Download.
Thanks it works
