Received Data from Slave
Hello, can someone please help me in this.
i'm trying to make the master-slave connection between 2 Arduino.
so This is the code used for the master and the slave, and the problem is in the received data from the slave, i dont get why its "? ? ? ?.."
Your help will be much appreciated.
Code slave:
// Include Arduino Wire library for I2C
#include <Wire.h>
// Define Slave I2C Address
#define SLAVE_ADDR 9
// Define Slave answer size
#define ANSWERSIZE 48
// Define nombre de NFC tag
#define TAGSNUM 4
// Define string with response to Master
String answer = "";
//Include RFID library
#include <SPI.h>
#include <MFRC522.h>
#define SS_PIN 10
#define RST_PIN 9
MFRC522 rfid(SS_PIN, RST_PIN); // Instance of the class
MFRC522::MIFARE_Key key;
// Init array that will store new NUID
byte nuidPICC[4];
int count = 0;
String tags[TAGSNUM];
// Setup Serial Monitor
Serial.println("OCEAN PROJET / SLAVE");
SPI.begin();
rfid.PCD_Init(); // Init MFRC522
for (byte i = 0; i < 6; i++) {
key.keyByte = 0xFF;
  • // Initialize I2C communications as Slave*
  • Wire.begin(SLAVE_ADDR);*
  • // Function to run when data received from master*
  • Wire.onReceive(receiveEvent);*
  • // Function to run when data requested from master*
  • Wire.onRequest(requestEvent);*
void receiveEvent() {
  • // Read while data received*
  • while (0 < Wire.available()) {*
  • byte x = Wire.read();*
  • // Print to Serial Monitor*
  • Serial.println("Receive event");*
    void requestEvent() {
  • for (byte i = 0; i < TAGSNUM; i++) {*
    _ Serial.println(tags*);_
    _
    }_
    _
    // Setup byte variable in the correct size*_
    * byte response[ANSWERSIZE];*
* // Format answer as one string for easy reading*
* for (byte i = 0; i < TAGSNUM; i++) {*
_ answer += tags*;
// Format response as array to send to master*
* for (byte i = 0; i < ANSWERSIZE; i++) {
response = (byte)answer.charAt(i);
//for (byte i = 0; i < ANSWERSIZE; i++) {
// Serial.print(response);
//}*_
* // Send response back to Master*
* Wire.write(response,sizeof(response));*
* // Print to Serial Monitor*
* Serial.println("Request event");*
* delay(500);*
* requestEvent();*
* // Reset the loop if no new card present on the sensor/reader. This saves the entire process when idle.*
* if ( ! rfid.PICC_IsNewCardPresent())
_ return;
// Verify if the NUID has been readed*
* if ( ! rfid.PICC_ReadCardSerial())*
* return;
// Check is the PICC of Classic MIFARE type*
* MFRC522::PICC_Type piccType = rfid.PICC_GetType(rfid.uid.sak);
if (piccType != MFRC522::PICC_TYPE_MIFARE_MINI &&
piccType != MFRC522::PICC_TYPE_MIFARE_1K &&
piccType != MFRC522::PICC_TYPE_MIFARE_4K) {*
* Serial.println(F("Your tag is not of type MIFARE Classic."));
return;
if (rfid.uid.uidByte[0] != nuidPICC[0] ||
rfid.uid.uidByte[1] != nuidPICC[1] ||
rfid.uid.uidByte[2] != nuidPICC[2] ||
rfid.uid.uidByte[3] != nuidPICC[3] ) {
// Serial.print(F("A new card has been detected. "));
// Store NUID into nuidPICC array*
* for (byte i = 0; i < 4; i++) {_
nuidPICC _= rfid.uid.uidByte;
tags[count] = printHex(rfid.uid.uidByte, rfid.uid.size);
Serial.print(F("The NUID tag is:"));
Serial.print(tags[count]);
count++;
else Serial.println(F("Card read previously."));
// Halt PICC*
* rfid.PICC_HaltA();*
* // Stop encryption on PCD*
* rfid.PCD_StopCrypto1();*
* Helper routine to dump a byte array as hex values to Serial.
String printHex(byte *buffer, byte bufferSize) {
String str = "";
for (byte i = 0; i < bufferSize; i++) {
str += (buffer < 0x10 ? " 0" : " ");
str += String(buffer, HEX);
//Serial.print(buffer < 0x10 ? " 0" : " ");
//Serial.print(buffer, HEX);
return str;
Code master:
// Include Arduino Wire library for I2C*
#include <Wire.h>
void setup() {_
* // Initialize I2C communications as Master*
* Wire.begin();*
* // Setup serial monitor*
* Serial.begin(9600);*
* Serial.println("MASTER");*
* delay(500);*
* Serial.println("Write data to slave");*
* // Write a charater to the Slave*
* Wire.beginTransmission(SLAVE_ADDR);
_ Wire.write(0);
Wire.endTransmission();*_
* Serial.println("Receive data");*
* // Read response from Slave*
* // Read back 5 characters*
* Wire.requestFrom(SLAVE_ADDR,ANSWERSIZE);*
* // Add characters to string*
* String response = "";*
* while (Wire.available()) {*
* char b = Wire.read();*
* response += b;*
* Serial.println(response);*
If you are following a tutorial, can you post a link to it.
This:
will probably exceed the size of the I2C buffer, which is usually 32 bytes.
thomasthomas:
Please, answer to the following question:
1. Which Arduino Board you are using as Master and which one as Slave.
2. Do you have pull-up resistors (2.2 k to 10k) on the I2C Bus?
3. Can you post your connection diagram?
4. Can you create a small sketch that will print this message: "Slave is found." on the Serial Monitor of Master? If yes, please post the codes here.
5. Can you modify/extend the sketch Step-4 so that when the Master sends "Hello." to Slave, only then the Slave will send "Yes." to Master? (The messages will appear on the Serial Monitors of the respective Serial Monitors.) If yes, please post the sketch here.
