receiving 5 (R,B,G) Values over serial. my ode doesn't work (15 3 digit values)
So, I have been trying to write a code for my PC Lighting, I’m planning to only to use (arduino for now, will make a custom board or something) it for receiving color of the 5 pixels.
the problem is, parseInt is so slow even with \n on the end, and serial.read() - ‘0’ reads only 1 digit at a time so 255 would be (2,2,5)
So i made a function named recieve, but the problem is i get my values like this, instead of zero i get 2 integers, the first one might be the value i send, the second one is something like -14000 etc,
#include "Adafruit_NeoPixel.h"
#include "WS2812_Definitions.h"
#define PIN 4
#define LED_COUNT 5
struct pixel {
  int R = 0;
  int B = 0;
  int G = 0;
Adafruit_NeoPixel leds = Adafruit_NeoPixel(LED_COUNT, PIN, NEO_GRB + NEO_KHZ800);
char count = 1;
int pixelNumber = 0;
struct pixel tempPixel;
//struct pixel Pixels[LED_COUNT];
  leds.begin();  // Call this to start up the LED strip.
  clearLEDs();   // This function, defined below, turns all LEDs off...
  leds.show();   // ...but the LEDs don't actually update until you call this.
  if(Serial.available() > 0) {
    if(count == 1) {
      tempPixel.R = PC_Receive();
    } else if (count == 2) {
      tempPixel.G = PC_Receive();
    } else if (count == 3) {
      tempPixel.B = PC_Receive();
      count = 0;
      setPixelColor(pixelNumber, tempPixel);
//      Serial.print("OK:");
      Serial.println(pixelNumber);
      leds.show();
//      Pixels[pixelNumber] = tempPixel;
      if(++pixelNumber >= LED_COUNT) {
        pixelNumber = 0;
    count++;
//  if(pixelNumber == 0) {
//    for(int i = 0; i < LED_COUNT; i++ ) {
//       setPixelColor(i, Pixels[i]);
//    leds.show();
void setPixelColor(int a, struct pixel P)
  leds.setPixelColor(a, P.R, P.G, P.B);
int PC_Receive() {
  int result;
  for(int i = 0; i < 3; i++) {
    while(Serial.available() <= 0);
      Serial.println(Serial.read() - '0');
      if(i = 0) { result = (Serial.read() - '0'; }
      if(i = 1) { result += (Serial.read() - '0') * 10; }
      if(i = 2) { result += (Serial.read() - '0') * 100; }
  Serial.println(result);
  return result;
The time that it takes parseInt() to collect data, recognize that the end of the value has arrived (no data for a period of time OR a non-numeric character arrived), and convert the value to an int depends on the baud rate. IF you send some non-numeric value after the last digit and use a decent baud rate, parseInt() is not slow. YOUR code might be.
Do you seriously think that available() can return a negative value?
If there IS a byte to read, read it and throw it away. Then, read a byte that hasn’t arrived…
That is NOT how to compare i to a number.
you certainly cannot count on all of your values being three decimal places…
on the transmit side, send the three values in a single packet, something like this:
byte red = 0;
byte green = 255;
byte blue = 155;
char txBuffer[10] = "";
sprintf(txBuffer"*%d|%d|%d#", red, green, blue);
Serial.println(txBuffer);
then on the receiving side, parse like this:
const int redPin = 5;
const int greenPin = 3;
const int bluePin = 6;
byte colorValue [3] = {0};
bool displayedNewValue = true;
  pinMode(redPin, OUTPUT);
  pinMode(greenPin, OUTPUT);
  pinMode(bluePin, OUTPUT);
  if(Serial.available())
    char myChar = Serial.read();
    if(myChar == '*') // found leading *
      for (int i = 0; i < 3; i++)
        colorValue[i] = Serial.parseInt();
        if(i!=2)
          Serial.read();  // ignore the pipe
          char lastChar;
          lastChar = Serial.read();
          if(lastChar != '#')  // expects a # ... abort if it didn't arrive
            Serial.println(F("bad read"));
            displayedNewValue = false;
        delay(10);
  if (!displayedNewValue)
    char packetContents[32];
    sprintf(packetContents, "Red:%3d Green:%3d Blue:%3d", colorValue[2], colorValue[1], colorValue[0]);
    Serial.println(packetContents);
    analogWrite(redPin, colorValue[2]);
    analogWrite(greenPin, colorValue[1]);
    analogWrite(bluePin, colorValue[0]);
Have a look at the examples in Serial Input Basics - simple reliable non-blocking ways to receive data. There is also a parse example.
...R
Thanks, before i visited here i wrote a new code that works, and im sure my input is 3 digits as max value for my pwm is 255;
char PC_Receive() {
  int result = 0;
  while(Serial.available() == 0);
  result += ((int)Serial.read() - '0') * 100;
  result += ((int)Serial.read() - '0') * 10;
  result += ((int)Serial.read() - '0');
  return result;
Why are you casting the int that Serial.read() returns to an int?
Short TEST code to read 3 bytes from serial port.
Reads 3 bytes into buffer and prints ( to LCD / serial monitor) 3 bytes from such buffer - A TEST CODE !
 char  SerialBuffer[256];
  do
    // test serial int
    while (!Serial.available());
    while (Serial.available())
      lcd_i2c.clear();
      lcd_i2c.print(__func__);
      lcd_i2c.setCursor(0, 1);
      //lcd_i2c.print((int) Serial.parseInt());
      //for (;;);
      //while (lcd_i2c.print((int) Serial.parseInt() != 0 ));
      //      lcd_i2c.setCursor(0, 2);
      // return number of characters in SerialBuffer
      lcd_i2c.print(Serial.readBytes(SerialBuffer, 3));
      //      lcd_i2c.setCursor(0, 3);
      //      lcd_i2c.print(Serial.print(SerialBuffer[0]));
      // print buffer
      for (int i = 0; i  != 3; i++)
        lcd_i2c.print(SerialBuffer[i]);
        Serial.print(SerialBuffer[i]);
      //      //for (;;);
      lcd_i2c.setCursor(16, 3);
      lcd_i2c.print(__LINE__);
      delay(DELAY);
      delay(5000);
      lcd_i2c.clear();
  } while (true);
  for (;;);
Perhaps you should provide a little more description of the data you are trying to send/receive. There may be better/easier ways of doing the task.
Im trying to control 5leds from my pc, i found a better way, i will send a hex numbers like this:
(0x(lednum)(g)(b)(r))
For example = 5FF0C00
I made a new post about a problem i had there,
