Receiving a two digit number in arduino UNO via bluetooth serial
Hello !
i am working with a project where i send a number "12" to arduino. When i receive the number and print it , it displays garbage characters with itself
Here is the code :
#include <SoftwareSerial.h>
#include <Servo.h>
Servo servo1;
Servo servo2;
int servo1angle=90;
int servo2angle=90;
String str = "";
int TX = 12;
int RX = 13;
char bufferr[2] ;
int i=0;
SoftwareSerial HC_06(TX, RX); //Bluetooth TX to 10 and Bluetooth RX to 11.
servo1.attach(7);
servo2.attach(8);
HC_06.begin(9600);
while(HC_06.available()> 0 )
char bytee = HC_06.read();
if(bytee >=48 && bytee<= 57)
bufferr = bytee;
  • i++;*
  • if(bytee == ':')*
  • //Serial.println(bufferr);*
  • str = bufferr;*
  • Serial.println(str);*
  • str = '\0';*
  • break;*
            bufferr = bytee;
            i++;
doesn't look right. i think you intended to do
           bufferr  [i++] = bytee;
but bufferr needs to have a terminating NULL character otherwise the print doesn't know where the end of the string is. bufferr needs to be at least 3 bytes long to hold a 2 character string and the 3rd byte needs to be set to NULL before printing.
you should also reinitialize i to 0 after receiving and processing 2 characters
