Receiving corrupted SMS messaage on Arduino+SIM900 shield
I am sending an SMS message to the Arduino+SIM900 shield. The SMS message is being corrupted when I am going thru the debugger. This corruption is happening only when I send it to Arduino, if I send this SMS message to another phone, everything is fine.
The code is below. I listed the whole code for completness, but the problem is happening at the very beginning when I am trying to read the message.
Any help greatly appreciated. (I suspect that I am in some different character set or something like that).
//   SmsCommand - Active Pin 13 On/OFF depending on the received SMS message (on/off).
//                This soft also send the PIN code to SIM card when appropriate.
//   Based on Serial Relay. Arduino will still patch a  serial link between the
//             computer and the GPRS Shield at 19200 bps 8-N-1.
//   *** Configure Serial Monitor to Carriage Return, 19200 bauds ***
//   *** VERY IMPORTANT!!!                                  ***
//   *** FOR READING SMS, DO NOT FORGET TO CHANGE           ***
//   *** THE BUFFER SIZE OF NewSoftSerial to 128 bytes      ***
//   ***   see line _NewSS_MAX_RX_BUFF in NewSoftSerial.h   ***
//      http://mchobby.be/wiki/index.php?title=GeekOnFire_GSM/GPRS_Shield
#include <SoftwareSerial.h>
SoftwareSerial mySerial(7, 8);
// EN: String buffer for the GPRS shield message
// FR: Mémoire tampon de type string pour les messages du shield GPRS
String msg = String("");
// EN: Set to 1 when the next GPRS shield message will contains the SMS message
// FR: Est mis à 1 quand le prochain message du shield GPRS contiendra le contenu du SMS
int SmsContentFlag = 0;
// EN: Pin of the LED to turn ON and OFF depending on the received message
// FR: Pin de la LED a allumer/éteindre en fonction du message reçu
int ledPin = 5;
// EN: Code PIN of the SIM card (if applied)
// FR: Code PIN de la carte SIM (si applicable)
String SIM_PIN_CODE = String( "3333" );
int8_t answer;
int x;
char SMS[200];
  mySerial.begin(19200);               // the GPRS baud rate
  Serial.println("Started!");
  // Initialize la PIN
  pinMode( ledPin, OUTPUT );
  digitalWrite( ledPin, HIGH );
    char SerialInByte;
    if(Serial.available())
       mySerial.print((unsigned char)Serial.read());
    else  if(mySerial.available())
        char SerialInByte;
        SerialInByte = (unsigned char)mySerial.read();
        // Relay to Arduino IDE Monitor - Here I get the corrupted characters!!!!!!!!!!!!
        Serial.print( SerialInByte );
        // Program also listen to the GPRS shield message.
        // If the message ends with <CR> then process the message
        if( SerialInByte == 13 ){
          // EN: Store the char into the message buffer
          ProcessGprsMsg();
         if( SerialInByte == 10 ){
            // EN: Skip Line feed
         else {
           // EN: store the current character in the message string buffer
           msg += String(SerialInByte);
      answer = 1;
     if (answer == 1)
        answer = 0;
        while(Serial.available() == 0);
        // this loop reads the data of the SMS
        do{
            if(Serial.available() > 0){    // if there are data in the UART input buffer, reads it and checks for the asnwer
                SMS[x] = Serial.read();
                x++;
                if (strstr(SMS, "OK") != NULL)    // check if the desired answer (OK) is in the response of the module
                    answer = 1;
                    Serial.println("Got it!");
        }while(answer == 0);    // Waits for the asnwer with time out
        SMS[x] = '\0';
        Serial.print(SMS);
        Serial.print("error ");
        Serial.println(answer, DEC);
// EN: Make action based on the content of the SMS.
//     Notice than SMS content is the result of the processing of several GPRS shield messages.
void ProcessSms( String sms ){
  sms.toLowerCase();
  Serial.print( "ProcessSms for [" );
  Serial.print( sms );
  Serial.println( "]" );
  if( sms.indexOf("on") >= 0 ){
    Serial.println( "LED IS ON" );
    return;
  if( sms.indexOf("off") >= 0 ){
    digitalWrite( ledPin, LOW );
    Serial.println( "LED IS OFF" );
    return;
// Send the SIM PIN Code to the GPRS shield
void GprsSendPinCode(){
  if( SIM_PIN_CODE.indexOf("XXXX")>=0 ){
    Serial.println( "*** OUPS! you did not have provided a PIN CODE for your SIM CARD. ***" );
    Serial.println( "*** Please, define the SIM_PIN_CODE variable . ***" );
    return;
  mySerial.print("AT+CPIN=");
  mySerial.println( SIM_PIN_CODE );
// Request Text Mode for SMS messaging
void GprsTextModeSMS(){
  mySerial.println( "AT+CMGF=1" );
void GprsReadSmsStore( String SmsStorePos ){
  // Serial.print( "GprsReadSmsStore for storePos " );
  // Serial.println( SmsStorePos );
  mySerial.print( "AT+CMGR=" );
  mySerial.println( SmsStorePos );
// Clear the GPRS shield message buffer
void ClearGprsMsg(){
  msg = "";
// interpret the GPRS shield message and act appropiately
void ProcessGprsMsg() {
  Serial.println("");
  Serial.print( "GPRS Message: [" );
  Serial.print( msg );
  if( msg.indexOf( "+CPIN: SIM PIN" ) >= 0 ){
     Serial.println( "*** NEED FOR SIM PIN CODE ***" );
     Serial.println( "PIN CODE *** WILL BE SEND NOW" );
     //GprsSendPinCode();
  if( msg.indexOf( "Call Ready" ) >= 0 ){
     Serial.println( "*** GPRS Shield registered on Mobile Network ***" );
     GprsTextModeSMS();
  // unsolicited message received when getting a SMS message
  if( msg.indexOf( "+CMTI" ) >= 0 ){
     Serial.println( "*** SMS Received ***" );
     // Look for the coma in the full message (+CMTI: "SM",6)
     // In the sample, the SMS is stored at position 6
     int iPos = msg.indexOf( "," );
     String SmsStorePos = msg.substring( iPos+1 );
     Serial.print( "SMS stored at " );
     // Ask to read the SMS store
     GprsReadSmsStore( SmsStorePos );
  // SMS store readed through UART (result of GprsReadSmsStore request)
  if( msg.indexOf( "+CMGR:" ) >= 0 ){
    // Next message will contains the BODY of SMS
    SmsContentFlag = 1;
    // Following lines are essentiel to not clear the flag!
    ClearGprsMsg();
    return;
  // +CMGR message just before indicate that the following GRPS Shield message
  //     (this message) will contains the SMS body
  if( SmsContentFlag == 1 ){
    Serial.println( "*** SMS MESSAGE CONTENT ***" );
    Serial.println( msg );
    Serial.println( "*** END OF SMS MESSAGE ***" );
    ProcessSms( msg );
  ClearGprsMsg();
  // Always clear the flag
  SmsContentFlag = 0;
What is the 'debugger'?
What message are you expecting to receive, and what do you actually receive? Is there any pattern to the 'corruption'?
Have you made the 'VERY IMPORTANT' change to the SoftwareSerial library that is mentioned in the code header?
Have you checked how much free memory your Arduino has when the sketch runs? If not, I suggest you add code to do that. You'll find sample code in the playground.
You have a very good point. I did not make 'VERY IMPORTANT' change to the SoftwareSerial library that is mentioned in the code header. However, how do I access this file. I have a line in the code.
How can I open this file and access this value? (I thought about this but I don't know even how to check this value).
Thank you
Although the comment refers to NewSoftSerial, that library has been adopted as the standard SoftwareSerial library. Unless your Arduino installation is very old, I would assume the comment refers to SoftwareSerial. The source for the SoftwareSerial library is in libraries\SoftwareSerial\SoftwareSerial.h under the Arduino installation directory - for example, C:\Program Files\Arduino on Windows, or wherever else you chose to install the IDE. The RX buffer size is defined near the top of the file (line 42 in my copy) and looks like this:
#define _SS_MAX_RX_BUFF 64 // RX buffer size
It's not common to have to hack the standard libraries like this but there's nothing stopping you if you want to do it - just remember what you changed so you can change it back to standard later.
