Hey everyone, I'm working on a sumo robot that uses four Ping sensors, the kind with 3 pins, to find targets. On previous attempts I could be lazy and use the pulseIn function- as found in the Ping example code- however this time around the team is using drill motors, which in terms of software behave identically to brushless. Because a lot of timing is required for motor control as well as other parts of the system, interrupts and delays (beyond a few micros) are out of the question- That includes pulseIn. Attempting to replace pulseIn with non-blocking code has been unsuccessful, generally resulting in the sensors firing but not returning data, or firing once and remaining off. So far as I can tell most of it boils down to:
Not understanding the return pulse of the ultrasonic sensor
Unsure of what pulseIn(pingPin, HIGH) is looking for and timing, several Arduino forum posts and the documentation differ on how it's triggered on/off
Thanks, much appreciated.
const int pingPin = 3;
unsigned long start = 0;
bool readingPulse = false;
int stage = 0;
// initialize serial communication:
unsigned long duration, inches, cm;
if(stage == 0){
stage = 1;
digitalWrite(13, LOW);
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
pinMode(pingPin, INPUT);
//here's where pulseIn would be
if(stage == 1){
if(digitalRead(pingPin) == HIGH && readingPulse == false){
start = micros();
readingPulse = true;
digitalWrite(13, HIGH);
else if(digitalRead(pingPin) == LOW && readingPulse == true){
stage = 0;
duration = micros() - start;
inches = microsecondsToInches(duration);
cm = microsecondsToCentimeters(duration);
Serial.print(inches);
Serial.print("in, ");
Serial.print(cm);
Serial.print("cm");
long microsecondsToInches(long microseconds) {
return microseconds / 74 / 2;
long microsecondsToCentimeters(long microseconds) {
return microseconds / 29 / 2;
(Obviously this is a modified version of the Ping example code. Trying to minimize points of failure before getting too custom, since that code works fine with the sensors)
