Receiving Data from temp. sensor and placing it in serial monitor using the Xbee
I am using the Arduino Uno and the Zigbee. I’m trying to make a data receiver basically. I have the code for the One wire ready to go but all I need is that sensor (18b20) to be wireless. For example, putting a wireless sensor into a server room to see the room temp. The baud rate is 9600 and yes I’m trying to make it display the sensor temp into the serial monitor. I’m using this:
to help me but it’s not quite working…\
here is the code I was talking about without the Xbee part
##include <OneWire.h>
#include <DallasTemperature.h>
OneWire oneWire(6); // datapin D6
DallasTemperature sensors(&oneWire);
float temp1, temp2, temp3;
  sensors.begin();
  sensors.requestTemperatures();
  temp1 = sensors.getTempCByIndex(0);
  temp2 = sensors.getTempCByIndex(1);
  temp3 = sensors.getTempCByIndex(2);
  Serial.print("Temp1: ");
  Serial.print(temp1, 1); // one decimal place
  //Serial.print(temp1, 4); // four decimal places
  Serial.println(" C");
  Serial.print("Temp2: ");
  Serial.print(temp2, 1);
  Serial.print("Temp3: ");
  Serial.print(temp3, 1);
  Serial.println(" C\n"); // extra newline
“There are lots of DS18B20 tutorials on the web for Arduino. YouTube is the wrong place to look, though.”
Hello?????
rclare15:
it's not quite working...\
The deafening silence might be broken if you were a little more coherent in your description of the problem. "Not quite" is meaningless. You apparently have a problem with XBee, yet you specifically exclude the XBee code in your post. You do not even say if the code you do post works.
