Receiving data with SerialIP
I am working with the SerialIP library to send and receive data from my arduino connected to a computer through a SLIP connection.
I’ve had ideas of pairing PHP with the serial port for the ability to put the data to be sent in the url (arduinohost/settempto?=56) but I’m not sure if SerialIP has the tools I need or if I should try to delve deeper.
The following reads a thermistor and sends the temperature to a browser:
 * SerialIP Hello World example.
 * SerialIP is a TCP/IP stack that can be used over a serial port (a bit
 * like a dial-up Internet connection, but without the modem.)  It works with
 * stock Arduinos (no shields required.)  When attached to a PC supporting
 * SLIP, the Arduino can host network servers and access the Internet (if the
 * PC is configured to share its Internet connection of course!)
 * SerialIP uses the fine uIP stack by Adam Dunkels <adam@sics.se>
 * For more information see the SerialIP page on the Arduino wiki:
 *   <http://www.arduino.cc/playground/Code/SerialIP>
 * This Hello World example sets up a server at 192.168.5.2 on port 1000.
 * Telnet here to access the service.  The uIP stack will also respond to
 * pings to test if you have successfully established a SLIP connection to
 * the Arduino.
 * SLIP connection set up under Linux:
 *  # modprobe slip
 *  # slattach -L -s 115200 -p slip /dev/ttyUSB0     (see note below)
 *  # ifconfig sl0 192.168.5.1 dstaddr 192.168.5.2
 *  # ping 192.168.5.2
 *  # telnet 192.168.5.2 1000
 * Here 192.168.5.1 is the address you will give to your PC, and it must be
 * unique on your LAN.  192.168.5.2 is the IP you will give the Arduino.  It
 * must also be unique, and must match the address the Arduino is expecting
 * as set by the "myIP" variable below.
 * Note that slattach won't return so you'll need to run ifconfig from
 * another terminal.  You can press Ctrl+C to kill slattach and release the
 * serial port, e.g. to upload another sketch.
 * This example was based upon uIP hello-world by Adam Dunkels <adam@sics.se>
 * Ported to the Arduino IDE by Adam Nielsen <malvineous@shikadi.net>
#include <SerialIP.h>
#include <Stdio.h>
#include <SoftwareSerial.h>
#include <math.h>
#define txPin 2
// The connection_data struct needs to be defined in an external file.
#include "HelloWorldData.h"
int temp;
int read;
char tempchar [3];
SoftwareSerial LCD = SoftwareSerial(0, txPin);
const int LCDdelay=10;  // conservative, 2 actually works
  // Set up the speed of our serial link.
  // Tell SerialIP which serial port to use (some boards have more than one.)
  // Currently this is limited to HardwareSerial ports, until both it and
  // SoftwareSerial inherit from a common base class.
  SerialIP.use_device(Serial);
  // We're going to be handling uIP events ourselves.  Perhaps one day a simpler
  // interface will be implemented for the Arduino IDE, but until then...
  SerialIP.set_uip_callback(uip_callback);
  // Set the IP address we'll be using.  Make sure this doesn't conflict with
  // any IP addresses or subnets on your LAN or you won't be able to connect to
  // either the Arduino or your LAN...
  IP_ADDR myIP = {192,168,5,2};
  IP_ADDR subnet = {255,255,255,0};
  SerialIP.begin(myIP, subnet);
  // If you'll be making outgoing connections from the Arduino to the rest of
  // the world, you'll need a gateway set up.
  //IP_ADDR gwIP = {192,168,5,1};
  //SerialIP.set_gateway(gwIP);
  // Listen for incoming connections on TCP port 1000.  Each incoming
  // connection will result in the uip_callback() function being called.
  SerialIP.listen(1000);
 pinMode(txPin, OUTPUT);
// pinMode(buttonOne, INPUT);
// pinMode(buttonTwo, INPUT);
  LCD.begin(9600);
  clearLCD();
  goTo(0,0);
  LCD.print("Hello world!");
  pinMode(13, OUTPUT);
  // Check the serial port and process any incoming data.
//  digitalWrite(13, HIGH);
//  delay(100);
  SerialIP.tick();
// digitalWrite(13, LOW);
//   delay(10);
  // We can do other things in the loop, but be aware that the loop will
  // briefly pause while IP data is being processed.
 // goTo(0,0);
 // clearLCD();
 // LCD.print("Temp: ");
 // LCD.print(temp);
void uip_callback(uip_tcp_appstate_t *s)
  if (uip_connected()) {
    // We want to store some data in our connections, so allocate some space
    // for it.  The connection_data struct is defined in a separate .h file,
    // due to the way the Arduino IDE works.  (typedefs come after function
    // definitions.)
    connection_data *d = (connection_data *)malloc(sizeof(connection_data));
    // Save it as SerialIP user data so we can get to it later.
    s->user = d;
    // The protosocket's read functions need a per-connection buffer to store
    // data they read.  We've got some space for this in our connection_data
    // structure, so we'll tell uIP to use that.
    PSOCK_INIT(&s->p, d->input_buffer, sizeof(d->input_buffer));
  // Call/resume our protosocket handler.
  handle_connection(s, (connection_data *)s->user);
  // If the connection has been closed, release the data we allocated earlier.
  if (uip_closed()) {
    if (s->user) free(s->user);
    s->user = NULL;
// This function is going to use uIP's protosockets to handle the connection.
// This means it must return int, because of the way the protosockets work.
// In a nutshell, when a PSOCK_* macro needs to wait for something, it will
// return from handle_connection so that other work can take place.  When the
// event is triggered, uip_callback() will call this function again and the
// switch() statement (see below) will take care of resuming execution where
// it left off.  It *looks* like this function runs from start to finish, but
// that's just an illusion to make it easier to code :-)
int handle_connection(uip_tcp_appstate_t *s, connection_data *d)
  // All protosockets must start with this macro.  Its internal implementation
  // is that of a switch() statement, so all code between PSOCK_BEGIN and
  // PSOCK_END is actually inside a switch block.  (This means for example,
  // that you can't declare variables in the middle of it!)
  PSOCK_BEGIN(&s->p);
  // READ THE TEMPERATURE AND SEND IT TO THE BROWSER.
  read = senRead();
  temp = getTemp(read);
  dtostrf(temp, 2, 0, tempchar);
  PSOCK_SEND_STR(&s->p, tempchar);
  PSOCK_SEND_STR(&s->p, " degrees ");
  // Read some returned text into the input buffer we set in PSOCK_INIT.  Data
  // is read until a newline (\n) is received, or the input buffer gets filled
  // up.  (Which, at 16 chars by default, isn't hard!)
  PSOCK_READTO(&s->p, '\n');
  // Since any subsequent PSOCK_* functions would overwrite the buffer, we
  // need to make a copy of it first.  We can't use a local variable for this,
  // because any PSOCK_* macro may make the function return and resume later,
  // thus losing the data in any local variables.  This is why uip_callback
  // has allocated the connection_data structure for us to use instead.  (You
  // can add/remove other variables in this struct to store different data.
  // See the other file in this sketch, serialip_conn.h)
  strncpy(d->name, d->input_buffer, sizeof(d->name));
  // Note that this will misbehave when the input buffer overflows (i.e.
  // more than 16 characters are typed in) but hey, this is supposed to be
  // a simple example.  Fixing this problem will be left as an exercise for
  // the reader :-)
  // Send some more data over the connection.
 // PSOCK_SEND_STR(&s->p, "Hello ");
 // PSOCK_SEND_STR(&s->p, d->name);
  // Disconnect.
  PSOCK_CLOSE(&s->p);
  // All protosockets must end with this macro.  It closes the switch().
  PSOCK_END(&s->p);
int senRead(){
  int one = analogRead(0);
  delay(100);
  int two = analogRead(0);
  delay(100);
  int three = analogRead(0);
  delay(100);
  int four = analogRead(0);
  delay(100);
  int five = analogRead(0);
  delay(100);
  int six = analogRead(0);
  delay(100);
  int seven = analogRead(0);
  delay(100);
  int eight = analogRead(0);
  return ((one + two + three + four + five + six + seven + eight) / 8);
int getTemp(int number){
    return (((.1718 * number) + -31.6792));
void goTo(int row, int col) {
  LCD.print(0xFE, BYTE);   //command flag
  LCD.print((col + row*64 + 128), BYTE);    //position
  delay(LCDdelay);
void clearLCD(){
  LCD.print(0x01, BYTE);   //clear command.
  delay(LCDdelay);
void backlightOn() {  //turns on the backlight
  LCD.print(0x7C, BYTE);   //command flag for backlight stuff
  LCD.print(100, BYTE);    //light level.
  delay(LCDdelay);
void backlightOff(){  //turns off the backlight
  LCD.print(128, BYTE);     //light level for off.
   delay(LCDdelay);
void serCommand(){   //a general function to call the command flag for issuing all other commands
I can’t wait to hear your responses. I am very novice and I hope I am headed in the right direction! Thank you.
