Receiving Data without Receiver with VirtualWire
first of all, sorry for my english.
But I want to receive Data from a RF Module and i can not, because i receive Noise, i think so. Because when I start the program (anything are connected), i receive rare symbols and i dont know why,
somebody know why?
Thanks !
I include what i in Serial Console received.
These is my receiver Code:
#include <VirtualWire.h>
int ledPin=13;
int rxPin =8;
void setup(){
Serial.begin(2000);
Serial.println("Arduino startet..");
pinMode(ledPin,OUTPUT);
vw_setup(10);
vw_set_rx_pin(rxPin);
vw_rx_start();
Serial.println("RF gestartet");
 uint8_t buf[VW_MAX_MESSAGE_LEN];
 uint8_t buflen=VW_MAX_MESSAGE_LEN;
 if(true){
   vw_get_message(buf,&buflen);
 int i;
     digitalWrite(ledPin,HIGH);
     Serial.print("Got: ");
     for(i=0;i<buflen;i++)
       Serial.print(buf[i],BIN);
       Serial.print(' ');
     digitalWrite(ledPin,LOW);
Please use code tags to post code ("</>" button) and post both the transmitter and receiver code.
Start over again with the working examples for VirtualWire. There are too many problems with what you posted – it will not work.
jremington:
I dont have transmitter, before i used a PUTTY (in TTL) to transmitter. but i received the same
To be useful, a receiver needs a transmitter.
jremington:
the transmitter was a PUTTY
was so: PUTTY → RF Transmitter RF Receiver-> Arduino → COM1 but these not work,
and now i have:
Arduino → COM1 and i have the same output, but i dont know why
I have no idea what you are trying to say, or do.
jremington:
I want to send data from PUTTY to Arduino no more but i dont receive anything
To use Virtualwire, you must have 2 Arduinos.
One doing the transmitting and one doing the receiving.
What type of transmitter and receiver are you using?
mauried:
I did these and anything..
I have these: http://www.ebay.de/itm/like/291648858582?lpid=106&chn=ps&ul_noapp=true
Great!
Post a wiring diagram (hand drawn, not Fritzing) for both your transmitting and receiving Arduinos, and post the code for both transmitter and receiver.
Then perhaps we can help.
jremington:
Great!
The Diagram is in the first post.
Receiver :
const int led_pin = 6;
const int transmit_pin = 12;
const int receive_pin = 11;
const int transmit_en_pin = 3;
   Serial.begin(9600); // Debugging only
   Serial.println("setup");
   // Initialise the IO and ISR
   vw_set_tx_pin(transmit_pin);
   vw_set_rx_pin(receive_pin);
   vw_set_ptt_pin(transmit_en_pin);
   vw_set_ptt_inverted(true); // Required for DR3100
   vw_setup(2000); // Bits per sec
   vw_rx_start();       // Start the receiver PLL running
   uint8_t buflen = VW_MAX_MESSAGE_LEN;
   if (vw_get_message(buf, &buflen)) // Non-blocking
int i;
       digitalWrite(led_pin, HIGH); // Flash a light to show received good message
// Message with a good checksum received, print it.
for (i = 0; i < buflen; i++)
   Serial.print(buf[i], HEX);
   Serial.print(' ');
       digitalWrite(led_pin, LOW);
Transmiter:
const int led_pin = 11;
const int receive_pin = 2;
byte count = 1;
 char msg[7] = {'h','e','l','l','o',' ','#'};
 msg[6] = count;
 digitalWrite(led_pin, HIGH); // Flash a light to show transmitting
 vw_send((uint8_t *)msg, 7);
 vw_wait_tx(); // Wait until the whole message is gone
 count = count + 1;
I take these to test from: VirtualWire Library, for very cheap wireless communication
I solved the Problem! the receiver was in another Frecuency! :smiley: thanks for all :slight_smile:
