Here is the code, but as I stated, the sketch works fine when connected to a PC but not the RPi.
Also, this is an
board: Arduino Nano
processor: ATmega328P (Old Bootloader)
port: /dev/ttyUSB0"
NEMA_23_BALL_SCREW_RHS_ROOF_FLAP_MATRIX_W_30A_FAN_AND_FLAPPER_FINAL
NEMA 23 RHS ROOF FLAP MATRIX USES ARDUINO NANO
STEPPERONLINE DM542T MOTOR CONTROLLERS SET TO PULSE/REV = 3200
USES 5VDC LIMIT SWITCH FOR HOMING [PIN 2]
PREASSEMBLED BALL SCREW SYSTEM
DAMPER ON FIRIGELLI INTERNAL ACTUATOR - RELAY [PINS 8, 10]
40A SOLID STATE RELAY FOR 30A CABIN RHS NACA FAN [5VDC SIGNAL INPUT] = NORMALLY CLOSED [PIN 12]
-JOHN ARMBRUSTER for ROUSHFENWAY RACING, LLC 8/9/21
#include <AccelStepper.h>
#include <MultiStepper.h>
// Define connections
#define LIMIT_SWITCH_FLAP 2 // RHS FLAP HOMING SWITCH
#define RHS_NACA_FAN_RELAY 12 // RHS NACA 30A FAN RELAY SWITCH
#define DAMPER_RELAY_1 8 // DAMPER RELAY 1
#define DAMPER_RELAY_2 10 // DAMPER RELAY 2
AccelStepper stepperFLAP(AccelStepper(1,4,6)); // PULSE/REV = 3200 on DM542T driver - pin 4 STEP, pin 6 DIR:
// Up to 10 steppers can be handled as a group by MultiStepper steppers;
// Stepper Travel Variables:
int FLAP = 0; // Travel steps of FLAP stepper
// Temporary values of stepper postition
int newFLAP = 0; // Travel steps of FLAP stepper
// FLAP STEP VARIABLES - DM542T CONTROLLER SET AT 3200 PULSE/REV: SET VARIABLES:
int ONE = 2985; // FLAP .787 INCHES
int TWO = 2879; // FLAP .759 INCHES
int THREE = 2819; // FLAP .743 INCHES
int FOUR = 2815; // FLAP .742 INCHES
int SET1 = 765; // FLAP .200 INCHES
int SET2 = 1521; // FLAP .400 INCHES
int SET3 = 2276; // FLAP .600 INCHES
int SET4 = 3032; // FLAP .800 INCHES
int SET5 = 383; // FLAP .100 INCHES
int SET6 = 1149; // FLAP .300 INCHES
int SET7 = 1915; // FLAP .500 INCHES
int SET8 = 2681; // FLAP .700 INCHES
int SET9 = 3447; // FLAP .900 INCHES
int SET10 = 3830; // FLAP 1.000 INCHES
/* ALTERNATE FLAP STEP VARIABLES - DM542T CONTROLLER SET AT 3200 PULSE/REV: SET VARIABLES:
int SET10 = 3830; // FLAP 1.000 INCHES */
// HOMING STEP VARIABLES INITIALIZED
long initial_homingFLAP = 1; // Used to Home FLAP Stepper at startup
int height; // variable to define flap height position string
const char *RHSFLAP[] = {"0: FLAP POSITION CLOSED", "1: FLAP POSITION .787 INCHES", "2: FLAP POSITION .759 INCHES", "5: FLAP POSITION .743 INCHES ", "7: FLAP POSITION .742 INCHES ", "a: FLAP POSITION CLOSED ", "b: FLAP POSITION CLOSED ", "c: FLAP POSITION .200 INCHES ", "d: FLAP POSITION .400 INCHES ", "e: FLAP POSITION .600 INCHES ", "f: FLAP POSITION .800 INCHES ", "g: FLAP POSITION .100 INCHES ", "h: FLAP POSITION .200 INCHES ", "i: FLAP POSITION .300 INCHES ", "j: FLAP POSITION .400 INCHES ", "k: FLAP POSITION .500 INCHES ", "l: FLAP POSITION .600 INCHES ", "m: FLAP POSITION .700 INCHES ", "n: FLAP POSITION .800 INCHES ", "o: FLAP POSITION .900 INCHES ", "p: FLAP POSITION 1.000 INCHES ", "q: FLAP POSITION .100 INCHES ", "r: FLAP POSITION .200 INCHES ", "s: FLAP POSITION .300 INCHES ", "t: FLAP POSITION .400 INCHES ", "u: FLAP POSITION .500 INCHES "}; // strings to define FLAP, FAN, DAMPER CONDITION position
// Setup the LIMIT SWITCHES as an Input:
pinMode(LIMIT_SWITCH_FLAP, INPUT_PULLUP);
// Setup ENABLE pins as Output
pinMode(RHS_NACA_FAN_RELAY, OUTPUT); // FAN RELAY HIGH TRIGGER
pinMode(DAMPER_RELAY_1, OUTPUT); // RELAY 1 HIGH TRIGGER
pinMode(DAMPER_RELAY_2, OUTPUT); // RELAY 2 HIGH TRIGGER
// Set RELAY pin to LOW (OFF)
digitalWrite(RHS_NACA_FAN_RELAY, LOW); // OFF
digitalWrite(DAMPER_RELAY_1, LOW); // OFF
digitalWrite(DAMPER_RELAY_2, LOW); // OFF
// Configure each stepper:
stepperFLAP.setMaxSpeed(5000);
// Then give them to MultiStepper to manage:
steppers.addStepper(stepperFLAP);
// initialize serial communication:
HOMING();
// read SERIAL MONITOR:
if (Serial.available() > 0) {
int inByteFLAP = Serial.read(); //Matrix 1 FLAP
// Array of desired stepper positions
long positions[20];
// MATRIX CASES
switch (inByteFLAP) {
case '0':
FLAP = 0;
OPENDAMPER();
FANOFF();
height = 0;
case '1':
FLAP = ONE;
CLOSEDDAMPER();
FANON();
height = 1;
case '2':
FLAP = TWO;
CLOSEDDAMPER();
FANON();
height = 2;
case '5':
FLAP = THREE;
CLOSEDDAMPER();
FANON();
height = 3;
case '7':
FLAP = FOUR;
CLOSEDDAMPER();
FANON();
height = 4;
case 'a': // WARM UP
FLAP = 0;
CLOSEDDAMPER();
FANON();
height = 5;
case 'b':
FLAP = 0;
CLOSEDDAMPER();
FANOFF();
height = 6;
case 'c':
FLAP = SET1 ;
CLOSEDDAMPER();
FANOFF();
height = 7;
case 'd':
FLAP = SET2;
CLOSEDDAMPER();
FANOFF();
height = 8;
case 'e':
FLAP = SET3;
CLOSEDDAMPER();
FANOFF();
height = 9;
case 'f':
FLAP = SET4;
CLOSEDDAMPER();
FANOFF();
height = 10;
case 'g':
FLAP = SET5;
CLOSEDDAMPER();
FANON();
height = 11;
case 'h':
FLAP = SET1;
CLOSEDDAMPER();
FANON();
height = 12;
case 'i':
FLAP = SET6;
CLOSEDDAMPER();
FANON();
height = 13;
case 'j':
FLAP = SET2;
CLOSEDDAMPER();
FANON();
height = 14;
case 'k':
FLAP = SET7;
CLOSEDDAMPER();
FANON();
height = 15;
case 'l':
FLAP = SET3;
CLOSEDDAMPER();
FANON();
height = 16;
case 'm':
FLAP = SET8;
CLOSEDDAMPER();
FANON();
height = 17;
case 'n':
FLAP = SET4;
CLOSEDDAMPER();
FANON();
height = 18;
case 'o':
FLAP = SET9;
CLOSEDDAMPER();
FANON();
height = 19;
case 'p':
FLAP = SET10;
CLOSEDDAMPER();
FANON();
height = 20;
case 'q':
FLAP = SET5;
OPENDAMPER();
FANOFF();
height = 21;
case 'r':
FLAP = SET1;
OPENDAMPER();
FANOFF();
height = 22;
case 's':
FLAP = SET6;
OPENDAMPER();
FANOFF();
height = 23;
case 't':
FLAP = SET2;
OPENDAMPER();
FANOFF();
height = 24;
case 'u':
FLAP = SET7;
OPENDAMPER();
FANOFF();
height = 25;
default:
// set positions to move to in steps
positions[0] = FLAP;
//execute move
steppers.moveTo(positions);
steppers.runSpeedToPosition();
// print arrival
//Serial.println(" ");
Serial.print("RHS FLAP ARRIVED AT: ");
Serial.print(RHSFLAP[height]);
void HOMING() { //Start Homing procedure of Stepper Motor at startup:
Serial.println("STEPPERS ARE HOMING_____________________________________");
// Home RHS FLAP stepper:
stepperFLAP.setMaxSpeed(10000); // Set Max Speed of Stepper (Slower to get better accuracy);
while (digitalRead(LIMIT_SWITCH_FLAP)) { // Make the FLAP Stepper move CCW until the switch is activated
Serial.println(digitalRead(LIMIT_SWITCH_FLAP));
stepperFLAP.moveTo(initial_homingFLAP); // Set the position to move to
Serial.println(initial_homingFLAP);
stepperFLAP.run(); // Start moving the stepper
initial_homingFLAP++; // Increase by 1 for next move if needed
stepperFLAP.setCurrentPosition(0); // Set the current position as zero for now
initial_homingFLAP = -1;
while (!digitalRead(LIMIT_SWITCH_FLAP)) { // Make the FLAP Stepper move CW until the switch is deactivated
stepperFLAP.run();
initial_homingFLAP--;
Serial.println("Homing RHS FLAP Completed");
stepperFLAP.setMaxSpeed(5000); // Set Max Speed of FLAP Stepper
Serial.println("___________________________________________________HOMED");
void OPENDAMPER() { // OPEN DAMPER
digitalWrite(DAMPER_RELAY_1, HIGH);
Serial.println("DAMPER OPEN");
void CLOSEDDAMPER() { // CLOSED DAMPER
digitalWrite(DAMPER_RELAY_2, HIGH);
Serial.println("DAMPER CLOSED");
void FANOFF() { // FAN OFF
Serial.println("FAN OFF");
void FANON() { // FAN ON
digitalWrite(RHS_NACA_FAN_RELAY, HIGH);
Serial.println("FAN ON");
