Receiving errors in ide while running code
Hello guys, I was recently working on a project which i saw on yt.
I got all the components and the necessary things to run but when I am running the code that have been given by the youtuber, I am facing error.
The code is given below.(The project title is RFID based attendance system, with esp32 devkit v1)
//>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>> 01_Test_RFID-RC522_Serial
// This code only takes the UID in string form.
// If you want to see more detailed information about an RFID card or keychain, please run the program code "DumpInfo".
// The "DumpInfo" program code is located at :
// Library folder "MFRC522" -> "examples" folder -> "DumpInfo" folder -> DumpInfo.ino
// or
// From Arduino IDE : File -> Examples -> MFRC522 -> DumpInfo
// or
// From Arduino IDE : File -> Examples -> INCOMPATIBLE-> MFRC522 -> DumpInfo
//----------------------------------------Including the libraries.
#include <SPI.h>
#include <MFRC522.h>
// Defines SS/SDA PIN and Reset PIN for RFID-RC522.
#define SS_PIN  5
#define RST_PIN 4
// Variable to read data from RFID-RC522.
int readsuccess;
char str[32] = "";
String UID_Result = "";
// Create MFRC522 object as "mfrc522" and set SS/SDA PIN and Reset PIN.
MFRC522 mfrc522(SS_PIN, RST_PIN);
//________________________________________________________________________________getUID()
// Subroutine to obtain UID/ID when RFID card or RFID keychain is tapped to RFID-RC522 module.
int getUID() {
  if(!mfrc522.PICC_IsNewCardPresent()) {
    return 0;
  if(!mfrc522.PICC_ReadCardSerial()) {
    return 0;
  byteArray_to_string(mfrc522.uid.uidByte, mfrc522.uid.size, str);
  UID_Result = str;
  mfrc522.PICC_HaltA();
  mfrc522.PCD_StopCrypto1();
  return 1;
//________________________________________________________________________________byteArray_to_string()
void byteArray_to_string(byte array[], unsigned int len, char buffer[]) {
  for (unsigned int i = 0; i < len; i++) {
    byte nib1 = (array[i] >> 4) & 0x0F;
    byte nib2 = (array[i] >> 0) & 0x0F;
    buffer[i*2+0] = nib1  < 0xA ? '0' + nib1  : 'A' + nib1  - 0xA;
    buffer[i*2+1] = nib2  < 0xA ? '0' + nib2  : 'A' + nib2  - 0xA;
  buffer[len*2] = '\0';
//________________________________________________________________________________VOID SETUP()
void setup(){
  // Init SPI bus.
  SPI.begin();
  // Init MFRC522.
  mfrc522.PCD_Init();
  Serial.println("Please tap your card or key chain to the RFID-RC522 module.");
//________________________________________________________________________________VOID LOOP()
void loop(){
  readsuccess = getUID();
  if(readsuccess){
    Serial.print("UID : ");
    Serial.println(UID_Result);
  delay(10);
The error i get is.
C:\Users\sugan\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.cpp: In member function 'MFRC522::StatusCode MFRC522Extended::TCL_Transceive(TagInfo*, byte*, byte, byte*, byte*)':
C:\Users\sugan\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.cpp:824:34: error: ordered comparison of pointer with integer zero ('byte*' {aka 'unsigned char*'} and 'int')
824 | if (backData && (backLen > 0)) {
C:\Users\sugan\Documents\Arduino\libraries\MFRC522\src\MFRC522Extended.cpp:847:42: error: ordered comparison of pointer with integer zero ('byte*' {aka 'unsigned char*'} and 'int')
847 | if (backData && (backLen > 0)) {
exit status 1
Compilation error: exit status 1
You don't seem to have a problem with IDE 2.x but more of a programming problem; therefore your topic has been moved to a more suitable location on the forum.
PS
Thanks for posting code using code tags in your first post :+1:
That's not a runtime error, it's a compile time error. The issue has been reported on the GitHub: https://github.com/miguelbalboa/rfid/issues/639
The note in the ReadMe doesn't look promising:
Find a better maintained library.
I ran into the same problem.
I reverted back to an earlier version of ESP32 in boards manager, and it worked for me.
