Receiving Multicast Packets With RN-XV WiFly Sheild
I am currently working on a project and am trying to receive multicast packets on an Arduino Uno with a roving networks RN-XV WiFly module.
I have posted a question in full, with examples of the code I am using, over at StackOverflow. If it better suits, I can copy the examples etc. here.
In short - though - I am wondering if anyone knows the C/Arduino command to join a group (similar to Java's MulticastSocket.joinGroup(IP_Address) method) as I am unable to have the Arduino/WiFly module receive packets on the 224.0.0.1 broadcast address.
I can, however, receive these packets with Java clients and am able to have the Arduino receive other UDP packets when they are sent across the local subnet broadcast (192.168.2.255) which leads me to believe the WiFly module just hasn't been told to listen for packets on 224.0.0.1.
Thank you very much! Any advice/help is greatly appreciated.
Edit: Will include code here too, for simplicity.
Below is the C code with which I am attempting to receive the data:
    if(wifly.available() > 0)
        int EoL = 0;
        String s;
        while(EoL == 0)
              char rec = wifly.read();
              if(rec != '\n')
                s += rec;
                EoL = 1;
        EoL = 0;
        Serial.println(s);
And the code with which I am sending the multicast packet:
MulticastSocket theOut = new MulticastSocket(55001);
String message = userInput;
byte[] buf = message.getBytes();
DatagramPacket packet = new DatagramPacket(buf, buf.length, InetAddress.getByName("224.0.0.1"), 2000);
DatagramPacket packetJ = new DatagramPacket(buf, buf.length, InetAddress.getByName("224.0.0.1"), 55000);
theOut.setBroadcast(true);
theOut.send(packet);//Send to Arduino port 2000
theOut.send(packetJ);//Send to Java port 55000
The Java Client code:
MulticastSocket theIn = new MulticastSocket(55000);
theIn.joinGroup(InetAddress.getByName("224.0.0.1"));
while ( true )                           // Loop
    byte[] buf = new byte[1024];
    DatagramPacket packet = new DatagramPacket(buf, buf.length);
    theIn.receive(packet);
    String mes = new String( packet.getData(),0,packet.getLength() );
    System.out.println(packet.getAddress().getHostAddress());
    System.out.println(packet.getPort());
    System.out.println(mes);
