Receiving Oregon sensor data on an XD-RF-5V
Or rather, not receiving anything !
I'm using an Arduino UNO, with an XD-RF-5V 433Mhz receiver (ubiquitous on eBay). My temperature probe is Oregon V3 THGR800, and it works well with the Oregon console. I can send and transmit 433 Mhz data with the RCswitch library. But I get nothing with the "Oregon decoder by Dominique Pierre" code.
Has anybody succeeded with that receiver, or should I get another model ?
The receiver should work, but in any case you should check its output with an oscilloscope or PC/sound card/Audacity to see if the incoming signal looks right, or needs to be inverted (it does need to be inverted on my setup). Here is an example http://jeelabs.net/projects/cafe/wiki/Decoding_the_Oregon_Scientific_V2_protocol
Also make sure you are using the correct version (2.1 or 3) code.
Thanks. I was considering buying a cheap oscilloscope anyway. Do you think the cheap Hantek 6022BE (60$ on eBay) will do ? And how do I know the signal is inverted ?
Some reviews of that scope: http://www.eevblog.com/forum/testgear/hantek-6022be-will-it-work-for-me/
To tell if the signal is inverted you will need an oscilloscope or Audacity trace, and compare your receiver's output with the traces that others have posted.
