Receiving pitch bend and handling problems
Hi everyone.
I just tried with Midi library getting incoming pitch bend data and use it for fading led. But I cannot get it to proper work.
Could you guys give me some advice how to do? How to write function?
#include <MIDI.h>
MIDI_CREATE_DEFAULT_INSTANCE();
const int led = 6;
void setup{
MIDI.begin(MIDI_CHANNEL_OMNI);
pinMode(led, OUTPUT);
MIDI.setHandlePitchBend(HandlePitchBend);
void HandlePitchBend(byte channel, byte bend){
unsigned int fade = map(bend,-8192.0,0.8191,0,255);
analogWrite(led, fade);
void loop(){
MIDI.read();
You pass into the function HandlePitchBend() a byte (unsigned 8 bits, 0-255) and then you map that into fade expecting the bend variable to be between -8192.0 and 0.8191. Please review the function definition of map() as it does not take floating point numbers and your variable you are ‘mapping’ is not a floating point number to start with.
I successfully fading led using CC messages even with note on, if note = 127, the led is full lighting and is proportional fade to 0 completely dark according to incoming notes. But with pitch bend I cannot.
Ok I close topic, I get it to work. I writing again function which works like I except.
void HandlePitchBend(int channel, int bend){
int fade = constrain(map(bend,-8192,8191,0,127),0,127);
blh64 thank you for advice.
