Receiving / Sending Serial Print from Arduino IDE to Android using MIT Apps
Hi. I'm currently working on something that need to transfer data from serial monitor to android.
I'm using
  • Arduino UNO Rev3
  • Bluetooth HC-05
  • MIT Apps
The data from serial monitor will be transferred to MIT apps on android using Bluetooth HC-05.
#include <SoftwareSerial.h>
#define rxPin 2                     // define SoftwareSerial rx data pin
#define txPin 3                     // define SoftwareSerial tx data pin
SoftwareSerial blueTooth(rxPin, txPin);  // create instance of SoftwareSerial
  Serial.begin(9600);            // Start hardware Serial
  blueTooth.begin(9600);         // Start SoftwareSerial
    char c;
     if (Serial.available())
       c = Serial.read();
       Serial.println(c);             // Write the character to the Serial Monitor
       blueTooth.write (c);           // Write the character to Bluetooth
This is the codes that I have tried but it doesn't display anything on the MIT apps.
Is the HC05 paired with the device that is running the MIT app?
Is the HC05 connected to the MIT app?
Is the Bluetooth module RX connected to Uno pin 3.
Is the Bluetooth module TX connected to Uno pin 2.
I have tried your code with my Uno and HC05. I successfully send data from serial monitor to Serial Bluetooth terminal on my tablet.
I suggest that you try connecting to Serial Bluetooth terminal. If you can talk to SB terminal but not the MIT app, there is a clue.
