Hello,
I am new to arduino so please bare with me. I currently have Arduino Uno R3 and Arduino Motor Shield. I have used Processing 1.5.1 to get 3D kinect data and then sent this information over to arduino as an integer value through serial ports.
I am trying to use this integer value to set a threshold for two motors labeled A and B to move faster when the user is far away. Basically having both wheels spin forward until the user's z-distance (information sent from kinect to arduino) is under a some threshold. I do not know how to access the data to begin setting up my constraint.
my code is as follows:
// give the motor control pins names:
const int pwmA = 3;
const int pwmB = 11;
const int brakeA = 9;
const int brakeB = 8;
const int dirA = 12;
const int dirB = 13;
Serial.begin(9600); //set up Serial library at 9600 bps
//Setup Channel A
pinMode(dirA, OUTPUT); //Initiates Motor Channel A pin
pinMode(brakeA, OUTPUT); //Initiates Brake Channel A pin
//Setup Channel B
pinMode(dirB, OUTPUT); //Initiates Motor Channel A pin
pinMode(brakeB, OUTPUT); //Initiates Brake Channel A pin
int get = 165;
int motorForward(){
analogWrite(pwmB, get);
analogWrite(pwmA, get);
//Motor A forward at half speed
digitalWrite(dirA, HIGH); //Establishes forward direction of Channel A
digitalWrite(brakeA, LOW); //Disengage the Brake for Channel A
//Motor B backward @ half speed
digitalWrite(dirB, LOW); //Establishes backward direction of Channel B
digitalWrite(brakeB, LOW); //Disengage the Brake for Channel B
Serial.println(get);
int motorBackward() {
digitalWrite(dirA, LOW); //Establishes backward direction of Channel A
analogWrite(pwmA, get); //Spins the motor on Channel A at half speed
digitalWrite(dirB, HIGH); //Establishes forward direction of Channel B
analogWrite(pwmB, get); //Spins the motor on Channel B at full speed
void loop(){
if(Serial.available())
motorForward();
motorBackward();
I have been experimenting with code and I'd like to control both motors independently and maintain a distance from the user with this data.
I attempted to write this code, but I do not know if I am going about this the right way, please help.
for(int=0; i<=n; i++) //accel. Motor from 0 to 255
{ analogWrite(pwmB, i);
analogWrite(pwmA, i);
delay(10);
I also do not know how to call the data sent in from serial.port some value like n in the for loop above. Thanks in advance.
