I am a complete Arduino beginner and I am having troubles with what I assume is a very basic task. I have found tutorials and examples such as this one: Serial Input Basics - updated - Introductory Tutorials - Arduino Forum
but I believe that significantly overcomplicates things, because they are trying to receive both numbers and letters.
I just want to turn a serial input of <01,1000> (from a raspberry pi that my friend is programming) into two variables to use for controlling location (01) and duration (1000) of a valve opening.
I will most likely be seeing locations between 01 and 32, as well as durations between 500ms and 30000ms. Is there any reason to send durations as 00500 instead of 500 because of the possibility of values with more significant figures (ex: 29000)?
I don't have any code to post because I really don't know where to start, sorry about that.
Also a little more detail on the process if you're interested, although I don't think its necessary for answering my question:
My friend is programming a raspberry pi to control an Arduino that I have to program, it will be sending it serial data somehow, in a format that we agree on, he has proposed the above format of <01,1000>. The Arduino will take that data, and then use it to open one of 32 valves to dispense liquid for between 500 and 30000 milliseconds. The commands from the pi will be coming in pretty slowly, probably every 10-20 seconds or so.
Robin's examples don't overcomplicate things; they provide a reliable way of communication.
There is no reason to send leading zeroes, it can make life more complicated as a leading zero indicates that the representation of the number is in octal (and e.g. 08 is invalid in that case).
clutchcurl:
As an admitted "complete beginner", you don't even know what you don't know.
Go with the tutorial that you cited, it's exactly what you need.
Which one of the examples he posted should I try to use? I would like to learn how the code works so I can use it in my project effectively, but it would be nice to have it narrowed down a bit.
clutchcurl:
This piece of code from my Tutorial just needs a small change to parse two numbers
void parseData() { // split the data into its parts
char * strtokIndx; // this is used by strtok() as an index
strtokIndx = strtok(tempChars,","); // get the first part - the string
strcpy(messageFromPC, strtokIndx); // copy it to messageFromPC
strtokIndx = strtok(NULL, ","); // this continues where the previous call left off
integerFromPC = atoi(strtokIndx); // convert this part to an integer
floatFromPC = atof(strtokIndx); // convert this part to a float
As written it is expecting a piece of text, an integer and a floating point value. You just need to change it so it receives two integer values - like this
integerFromPC = atoi(strtokIndx); // convert it to an integer
integer2FromPC = atoi(strtokIndx); // and this part
