Hello there,
I wired up my dht11 Sensor to my “wemos” d1 mini and tried to read data from it using this code:
#include "DHT.h"
DHT dht;
Serial.println("Status\tHumidity (%)\tTemperature (C)\t(F)");
dht.setup(5); // data pin 2
delay(dht.getMinimumSamplingPeriod());
float humidity = dht.getHumidity();
float temperature = dht.getTemperature();
Serial.print(dht.getStatusString());
Serial.print("\t");
Serial.print(humidity, 1);
Serial.print("\t\t");
Serial.print(temperature, 1);
Serial.println(dht.toFahrenheit(temperature), 1);
I wired it up like i used to do with my arduino nano where everything works fine (see attachments)
This is the Output I get:
Timeout nan nan nan
Timeout nan nan nan
Timeout nan nan nan
Timeout nan nan nan
Thanks for helping me out.
Frekkel:
DHT dht;
i think your forgot to add DHTTYPE and dht.begin() sir
pylon
August 7, 2018, 11:57am
#3
Yes, but the Nano is a 5V board while the Wemos is a 3V3 board. Connect Vcc to 3V3 and add a pull-up (10kΩ) from the Data pin to 3V3.
Post a link to the library you're actually using. Many DHT libraries use AVR-specific registers and cannot be used on ESP hardware.
pylon:
This is the library i am using.
pylon:
Tried it out but i am still getting the same results.
pylon
August 7, 2018, 3:54pm
#6
On that line:
the comment is wrong and according to the circuit it must read
dht.setup(D5); // data pin 2
For the AVR platform pin 5 and pin D5 are identical. This is not the case for the ESP platform.
pylon:
On that line:
I tried this out but I am still getting the Timeout nan nan nan Error I described earlier
Thanks for your help anyways
pylon
August 9, 2018, 8:27am
#8
Did you check if the D5 pin of your Wemos is still working? The wrong connection of the DHT to 5V might have fried it.
Make a simple sketch that puts out HIGH and LOW in a frequency of 0.1Hz, then check the output with a multimeter.
Make another sketch that prints the input value of D5 to the serial interface and check that value if you connect the pins to Vcc over a 5kΩ resistor or to GND using the same resistor.
