Hey Guys,
i have this project i want to send and receiving messages to a pc from an arduino with i2c-sensor.
i have a small w5500 ethernet-shield and using the ethernet3-libary. the pc has touch designer which gets the sensor data and than send out data which should control a led connected to the arduino.
sending data out from the arduino works perfectly but i have some problems getting the receive done.
i tried to send messages to test with packet sender and with touch designer.
#include <MPU6050_tockn.h>
#include <Wire.h>
#include <SPI.h>
#include <Ethernet3.h>
#include <FastLED.h>
#include <EthernetUdp3.h>
byte mac[] = {
0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED
IPAddress ip(192, 168, 0, 18);
#define IP "192.168.0.17"
#define NUM_LEDS 1
#define DATA_PIN 5
CRGB leds[NUM_LEDS];
unsigned int localPort = 8888; // local port to listen on
EthernetUDP Udp;
char packetBuffer[UDP_TX_PACKET_MAX_SIZE];
MPU6050 mpu6050(Wire);
Wire.begin();
mpu6050.begin();
mpu6050.calcGyroOffsets(true);
// FastLED.addLeds<WS2811, DATA_PIN, RGB>(leds, NUM_LEDS);
FastLED.addLeds<WS2812, DATA_PIN, RGB>(leds, NUM_LEDS);
Ethernet.begin(mac, ip);
//Ethernet.hardreset();
//Ethernet.softreset();
Udp.begin(localPort);
mpu6050.update();
int packetSize = Udp.parsePacket();
Udp.beginPacket(IP, 8888);
Udp.print("+");
Udp.print(mpu6050.getTemp());
Udp.print("+");
Udp.print(mpu6050.getAngleX());
Udp.print("+");
Udp.print(mpu6050.getAngleY());
Udp.print("+");
Udp.print(mpu6050.getAngleZ());
Udp.print("+");
Udp.print(mpu6050.getAccX());
Udp.print("+");
Udp.print(mpu6050.getAccY());
Udp.print("+");
Udp.print(mpu6050.getAccZ());
Udp.endPacket();
if (packetSize){
Udp.read(packetBuffer, UDP_TX_PACKET_MAX_SIZE);
Serial.println(packetBuffer);
leds[0] = CRGB(0,255,0);
FastLED.show();
delay(50);
system
November 8, 2018, 10:14am
2
Since you didn't tell us what the problems are, there doesn't seem much point in your having wasted your time posting.
juliusb
November 10, 2018, 9:51pm
3
hi, sorry for not being that clear.
i just dont get any data from the pc to the arduino,
im sending 3 bytes to control rgb of the led connected to the arduino. when testing with serial.print i dont get any data (just an "=" is printed to the monitor)
then i tried to send the data back via udp.print to test.
i try to parse the data like that:
#include <Wire.h>
#include <SPI.h>
#include <string.h>
byte mac[] = {
#define NUM_LEDS 1
#define DATA_PIN 5
EthernetUDP Udp;
#define UDP_TX_PACKET_MAX_SIZE 3
byte red;
byte green;
byte blue;
int Red;
int Green;
int Blue;
Wire.begin();
mpu6050.begin();
mpu6050.update();
if (packetSize) {
red = packetBuffer[0];
green = packetBuffer[1];
blue = packetBuffer[2];
Red = atoi(red);
Green = atoi(green);
Blue = atoi(blue);
// Serial.print(red);
// Serial.print(green);
// Serial.println(blue);
// Udp.print(packetBuffer);
Udp.print(Red);
Udp.print("+");
Udp.print(Green);
Udp.print("+");
Udp.print(Blue);
Udp.print("+");
//// Udp.print(mpu6050.getGyroAngleX());
//// Udp.print("+");
//// Udp.print(mpu6050.getGyroAngleY());
//// Udp.print(mpu6050.getGyroAngleZ());
//// Udp.print(mpu6050.getGyroX());
//// Udp.print(mpu6050.getGyroY());
//// Udp.print(mpu6050.getGyroZ());
Udp.endPacket();
//leds[0] = CRGB(0, 255, 0);
//FastLED.show();
delay(20);
system
November 12, 2018, 9:03am
4
byte red;
byte green;
byte blue;
int Red;
int Green;
int Blue;
Explain this.
Red = atoi(red);
Blue = atoi(blue);
And this. What does atoi() take as input? Here's a hint. It is NOT a byte.
