Receiving value over serial and displaying on 4-digit 7-segment LED
I want to read a JSON value and pass it to the arduino over the USB’s serial connection, then write it to a 7-segment display.
The following python script is reading the value:
import os
import sys
import serial
import time
import signal
import urllib
import json
PORT = '/dev/tty.usbmodem'
SPEED = 9600
connection = serial.Serial( PORT,  SPEED, timeout=0, stopbits=serial.STOPBITS_T$
while True:
        url = 'https://api.url.com'
        result = json.load(urllib.urlopen(url))
        writeme = result["value"]
        print writeme
        connection.write(str(writeme))
        time.sleep(5);
And the following runs on the arduino:
#include "SevSeg.h"
SevSeg myDisplay;
char writeme[7];
char inChar;
byte index=0;
  int displayType = COMMON_ANODE;
  int digit1 = 12;
  int digit2 = 11;
  int digit3 = 10;
  int digit4 = 13;
  int segA = 2;
  int segB = 4;
  int segC = 6;
  int segD = 8;
  int segE = 9;
  int segF = 3;
  int segG = 5;
  int segDP= 7;
  int numberOfDigits = 4;
  myDisplay.Begin(displayType, numberOfDigits, digit1, digit2, digit3, digit4, segA, segB, segC, segD, segE, segF, segG, segDP);
  myDisplay.SetBrightness(40);
while (Serial.available() > 0) {
  index = 0;
  while (index < 6)
           inChar = Serial.read();
           writeme[index] = inChar;
           index++;
       Serial.flush();
  myDisplay.DisplayString(writeme, 0);
What I’m getting is the value flashes to the LED for a brief moment, and then takes 5 seconds to do it again.
How can I keep the value displayed on the LED?
No comment on the first bit of code, I assume it is fine anyway.
This might help with the second
http://playground.arduino.cc//Main/MAX72XXHardware
http://forum.arduino.cc/index.php?topic=172192.0
