Bonjour à tous,
J'utilise une Carte arduino UNO avec un GSM shield Arduino (puce M10), j'essais deux type de programme : un pour envoyer des SMS et l'autre pour en recevoir.
Mon code de l'envois :
#include <GSM.h>
#define PINNUMBER ""
// initialize the library instance
GSM gsmAccess; // include a 'true' parameter for debug enabled
GSM_SMS sms;
// char array of the telephone number to send SMS
// change the number 1-212-555-1212 to a number
// you have access to
char remoteNumber[20]= "+33683894495";
// char array of the message
char txtMsg[200]="Ca marche !!!!!";
// initialize serial communications
Serial.println("SMS Messages Sender");
// connection state
boolean notConnected = true;
// Start GSM shield
// If your SIM has PIN, pass it as a parameter of begin() in quotes
while(notConnected)
if(gsmAccess.begin(PINNUMBER)==GSM_READY)
notConnected = false;
Serial.println("Not connected");
Serial.println("GSM initialized");
sendSMS();
// nothing to see here
void sendSMS(){
Serial.print("Message to mobile number: ");
Serial.println(remoteNumber);
// sms text
Serial.println("SENDING");
Serial.println("Message:");
Serial.println(txtMsg);
// send the message
sms.beginSMS(remoteNumber);
sms.print(txtMsg);
sms.endSMS();
Serial.println("\nCOMPLETE!\n");
Mon code pour la reception :
SMS receiver
This sketch, for the Arduino GSM shield, waits for SMS messages
and displays them through the Serial port.
Circuit:
* GSM shield
created 25 Feb 2012
by Javier Zorzano / TD
This example is in the public domain.
// libraries
#include <GSM.h>
// PIN Number
GSM_SMS sms;
char remoteNumber[20]; // Holds the emitting number
Serial.println("SMS Messages Receiver");
// connection state
// Start GSM shield
while(notConnected)
Serial.println("Waiting for messages");
char c;
//Serial.println("etape ok");
// If there are any SMSs available()
if (sms.available())
Serial.println("Message received from:");
// Get remote number
sms.remoteNumber(remoteNumber, 20);
// This is just an example of message disposal
// Messages starting with # should be discarded
if(sms.peek()=='#')
Serial.println("Discarded SMS");
sms.flush();
// Read message bytes and print them
while(c=sms.read())
Serial.print(c);
Serial.println("\nEND OF MESSAGE");
// delete message from modem memory
sms.flush();
Serial.println("MESSAGE DELETED");
J'arrive à envoyer les SMS avec le premier code mais je n'arrive pas a les recevoir sur ma liaison série avec le deuxième.
Quand j'envois le message sur ma carte GSM, il n'y a rien qui arrive. Si je met la carte SIM dans un autre portable les messages arrivent tous en rafale !!!
Est ce que qqn peut m'expliquer si il y a qque chose qui manque soit dans mon programme soit dans mon câblage ?
Merci
