Rechargeable battery for posture sensor
Hello everyone, I am trying to create a posture sensor similar to this one
Actually I have a prototype made of:
  • Arduino Nano
  • Gyro sensor (GY-521 with a MPU6050)
  • active buzzer (but I plan to replace it with a vibrating motor to make it more discrete)
I would like to place the sensor under the neck like the UpRight linked, sticking it with an adhesive or using it with a necklace. The gyro is used to detect when I am in a bad posture and it makes the buzzer sound (eventually the motor vibrate). The prototype is actually working.
Now I would like to add to the project a rechargeable battery, but it's one of my first project so I don't know how to move. I need a lightweight battery of course because otherwise the device will fall if I stick it, or will break my neck if I will use it with a necklace.
I have tought about 2 different solutions:
  • using a rechargeable battery, soldered or anyway not removable, with a on/off switch like this to turn off the device. That would mean adding something to recharge the battery, I don't know anything about this, but I think something like this. The problem in this case would be that the recharge module and the switch will take space into the device, and in addition I don't know anything about rechargeable batteries so I am little concerned about safety issues (like, can I charge it while the device is running? Can I charge while it is connected to the device?)
  • using a removable rechargeable battery, that would help me saving some space, which is essential because the device should be as little as possible, because I could just remove the battery when I want to recharge it or I want to turn off the device. The problem in this case would be that I am saving space without the switch and the module, but the only battery I have found to be easy removed and recharged would be this that is way too big (I think that the battery sould be something like this, which is 45mm x 25mm x 7mm), and in addittion is 9V which I don't need (I think the device could work on 3.3V, for sure on 5V)
Regarding the mAh needed I really don't know now, It would be ok if the sensor could run for 12 hours, but I don't know how much current it absorbs know, I have a multimeter but I think it's pointless to measure the current absorbed now without the vibrating motor
So I would like to have some advice: what do you think is the best solution? How would you do this? Is there some solution I haven't thought about? Thank you
EDIT: I measured the current absorbed with a 9V battery, it is 30mAh if the buzzer is not sounding, and 52mAH if it is sounding. The motor will absorb 60-100mAh depending on the volts, anyway I think that a battery with a capacity of 500mAh should be fine to make it lasts 12 hours
Pretty difficult to make any battery suggestions when you have no clue as to the requirements for the battery.
Use a piezo, such as in a smoke alarm, but add a plastic probe to contact the skin.
A Nano uses a lot of current to run and requires 5 volts. Look at some microcontroller that uses 3.3 or less voltage.
Paul
Why do you suggest a piezo?
Why a probe to contact the skin?
So Nano need 5V or more? Is there any battery that can help me?
matteo5v5:
A piezo is small, 1 inch in diameter, is very thin, 1/8 inch or less. Direct contact with skin will quickly corrode the piezo surface.
You already know a nano needs 5 volts.
Paul
Actually I tought that the nano could run on 3.3V, so doing I research I think I'll need a Nano 33 IOT which has also the gyro integrated, right?
I can't understand why you suggest a piezo, I tought a piezo was something like a buzzer, so it makes a sound, but I would like to have something vibrate which is more discrete than something that produces a sound... I don't know if I have understood well, can you link something like the piezo that you are talking about? Thank you.
I edited the post adding the measurements of the current absorbed, with a 9V battery is 30mAh in standby, and should be around 130mAh when the motor is vibrating, so I think 500mAh should be ok to make it run 12 hours
matteo5v5:
A piezo responds with vibrations at the frequency of the alternating voltage you apply to it. If you use a low enough frequency, the piezo will vibrate and you won't hear it. Experiment!
Paul
So the piezo that you are talking about is a passive buzzer?
Any suggestion regarding the battery? Thank you.
