Rechargeable battery powered spinning RGB LED gadget
Hello,
I am hoping to build a spinning LED gadget using some strip lighting RGB LEDs and a quartz clock mechanism. I would like to use this small project to increase my electronics knowledge so I just have some questions regarding my project that I would love some advice on. I would like the following features on this gadget:
The main questions I have are the following:
As mentioned, I would love to know what the most suitable hardware is to minimize both space and cost. I don't expect anyone to answer all of the above questions - just hoping that if you have any thoughts/experience on any of the questions I have, you can please share them here.
Thank you!
I see no features. Also no questions. Well that should be easy enough.
Steve
Things like this go better when the readers have a detailed description of your objective. Anything rotary, for example, you may want to look at brush type, slip ring type or other rotary connectors. Unless you have an idea of what you want, which you can describe in some detail, I don't know what you want.
Ron
