I know this has been asked before, but I still can't seem a solid answer. What's the procedure for sending a series of integers thru serial port in a way arduino can recognize and parse? Here's my code- the arduino side of it is pretty limited as I've mostly been working in processing.
Arduino Code
[code]
#include <SoftwareSerial.h>
boolean started = false;
boolean ended = true;
int recLine;
int recVars[12]; // Data received from the serial port
int ledPin = 13; // Set the pin to digital I/O 13
int serialIn;
int incomingByte;
boolean code = false;
pinMode(ledPin, OUTPUT); // Set pin as OUTPUT
Serial.begin(9600); // Start serial communication at 9600 bps
while (Serial.available()) { // If data is available to read,
int incomingBtye = Serial.read();
if(incomingBtye == 9) {
started = true;
ended = false;
else if(incomingByte == 999) {
code = true;
else if(incomingByte == 8) {
ended = true;
else {
recVars[serialIn] = incomingByte;
serialIn++;
recVars[serialIn] = '\0';
if(code == true ){
digitalWrite(ledPin,HIGH);
[/code]
Processing Code
int letter;
int ypos = 25;
int Step = 0;
String input = " ";
String currentString = " ";
String distance;
boolean distanceRec = false;
float distanceFloat;
int distanceInt; //SV0
String timer1;
boolean timer1Rec = false;
float timer1Float;
int timer1Int; //SV2
String relayTimer;
boolean relayTimerRec = false;
float relayTimerFloat;
int relayTimerInt; //SV4
String timer2;
boolean timer2Rec = false;
float timer2Float;
int timer2Int; //SV6
String speed;
boolean speedRec = false;
float speedFloat;
int speedInt; //SV8
String confirm;
boolean confirmVal = false;
int sendVars[] = {999,distanceInt,0,timer1Int,0,relayTimerInt,0,timer2Int,0,speedInt,888};
import processing.serial.*;
Serial myPort;
size(640, 900);
// Create the font
textFont(createFont("SourceCodePro-Regular.ttf", 36));
//Serial (quote to deactive debug)
// printArray(Serial.list());
myPort = new Serial(this, Serial.list()[1], 9600);
void draw() {
background(0);
textSize(14);
text("Click on the program to begin, enter distance", 25, 25);
text(input, 25, ypos, 540, 800);
if(distanceRec == true && Step > 0) {
text("Distance= ", 25, 400);
text(distance, 100 ,400);
text("Enter Timer 1" ,25, 50);
if(timer1Rec == true && Step > 0) {
text("Timer 1= ", 25, 425);
text(timer1, 100 ,425);
text("Enter Relay Time", 25, 75);
if(relayTimerRec == true && Step > 0) {
text("Relay Timer= ", 25, 450);
text(relayTimer, 125 ,450);
text("Enter Timer 2", 25, 100);
if(timer2Rec == true && Step > 0) {
text("Timer 2= ", 25, 475);
text(timer2, 100 ,475);
text("Enter Speed", 25, 125);
if(speedRec == true && Step > 0) {
text("Speed= ", 25, 500);
text(speed, 100 ,500);
text("CONFIRM THESE VALUES? Y/N", 25, 150);
if(confirmVal == true && Step > 0) {
text("Executing...", 25, 525);
text(distance, 0, 550);
text(timer1, 100, 550);
text(relayTimer, 200, 550);
text(timer2, 300, 550);
text(speed, 400, 550);
// myPort.write(distance);
// println(distance);
noLoop();
void keyTyped() {
letter = key;
input = input + key;
if(letter == ENTER && Step == 0) {
distanceFloat = Float.parseFloat(input);
//println(distanceFloat);
distanceInt = int(distanceFloat);
sendVars[1] = distanceInt;
distance = input;
distanceRec = true;
Step++;
letter = 0;
input = " ";
ypos+=25;
if(letter == ENTER && Step == 1) {
timer1Float = Float.parseFloat(input);
timer1Int = int(timer1Float);
sendVars[3] = timer1Int;
timer1 = input;
timer1Rec = true;
Step++;
letter = 0;
input = " ";
ypos+=25;
if(letter == ENTER && Step == 2) {
relayTimerFloat = Float.parseFloat(input);
relayTimerInt = int(relayTimerFloat);
sendVars[5] = relayTimerInt;
relayTimer = input;
relayTimerRec = true;
Step++;
letter = 0;
input = " ";
ypos+=25;
if(letter == ENTER && Step == 3) {
timer2Float = Float.parseFloat(input);
timer2Int = int(timer2Float);
sendVars[7] = timer2Int;
timer2 = input;
timer2Rec = true;
Step++;
letter = 0;
input = " ";
ypos+=25;
if(letter == ENTER && Step == 4) {
speedFloat = Float.parseFloat(input);
speedInt = int(speedFloat);
sendVars[9] = speedInt;
speed = input;
speedRec = true;
Step++;
letter = 0;
input = " ";
ypos+=25;
if(letter == 121 || letter == 89 && Step == 5) { //if Y or y
// println(sendVars[0],sendVars[1],sendVars[2],sendVars[3],sendVars[4],sendVars[5],sendVars[6],sendVars[7],sendVars[8],sendVars[9],sendVars[10]); //send value + space + 0 + space + nextValue "..." + ArrayEnd
for (int i = 0; i < 11; i++) {
myPort.write(sendVars[i]);
print(sendVars[i]);
// myPort.write(sendVars[10]);
// println(sendVars[1]);
confirm = input;
confirmVal = true;
Step = 0;
letter = 0;
input = " ";
ypos = 25;
timer1Rec = false;
timer2Rec = false;
speedRec = false;
timer1 = " ";
relayTimer = " ";
timer2 = " ";
speed = " ";
input = " ";
confirmVal = false;
if(letter == 78 || letter == 110 && Step == 5) { //if N or n
timer1Rec = false;
timer2Rec = false;
speedRec = false;
distance = " ";
timer1 = " ";
relayTimer = " ";
timer2 = " ";
speed = " ";
input = " ";
letter = 0;
Step = 0;
//exit();
// redraw();
