Recieving UDP message to control 32 booleans
Hello,
I'm very new to Arduino programming so I need some help with UDP messages.
I am using the program MAX MSP to send UDP messages to an Arduino MEGA with an ethernet shield attached. I aim to be able to control 32 solenoids with the Arduino by sending some kind of UDP message. What is the best type of message for me to send to control and separate these simple booleans and how do I translate the incoming UDP strings in the right way?
I have this code (based on the UDPsendRecieveString example) running and working but the packet contents just reads as list, int, and so on at the moment.
#include <SPI.h>
#include <Ethernet.h>
#include <EthernetUdp.h>
#define SDSelect  4
// Enter a MAC address and IP address for your controller below.
// The IP address will be dependent on your local network:
byte mac[] = {
  0xA8, 0x61, 0x0A, 0xAF, 0x03, 0xBC
IPAddress ip(192, 168, 1, 56);
IPAddress dns(8, 8, 8, 8);
IPAddress gateway(192, 168, 1, 57);
IPAddress subnet(255, 255, 255, 0);
unsigned int localPort = 8888;      // local port to listen on
// buffers for receiving and sending data
char packetBuffer[255];  // buffer to hold incoming packet,
// An EthernetUDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
  Ethernet.init(10);  // Most Arduino shields
  delay(10);
  pinMode (SDSelect, OUTPUT);
  digitalWrite (SDSelect, HIGH);
  delay(10);
  // start the Ethernet
  Ethernet.begin(mac, ip, dns, gateway, subnet);
  delay(10);
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  delay(10);
  // Check for Ethernet hardware present
  if (Ethernet.hardwareStatus() == EthernetNoHardware) {
    Serial.println("Ethernet shield was not found.  Sorry, can't run without hardware. :(");
    while (true) {
      delay(1); // do nothing, no point running without Ethernet hardware
  else if (Ethernet.hardwareStatus() == EthernetW5500) {
    Serial.println("W5500 Ethernet controller detected.");
  delay(3000);
  if (Ethernet.linkStatus() == LinkOFF) {
    Serial.println("Ethernet cable is not connected.");
  else if (Ethernet.linkStatus() == LinkON) {
    Serial.println("Ethernet cable is found, all good.");
  else if (Ethernet.linkStatus() == Unknown) {
    Serial.println("Link status unknown.");
  while(!Ethernet.linkStatus() == LinkON) {
  delay(100);
  // start UDP
  Udp.begin(localPort);
  // if there's data available, read a packet
  int packetSize = Udp.parsePacket();
  if (packetSize) {
    Serial.print("Received packet of size ");
    Serial.println(packetSize);
    Serial.print("From ");
    IPAddress remote = Udp.remoteIP();
    for (int i=0; i < 4; i++) {
      Serial.print(remote[i], DEC);
      if (i < 3) {
        Serial.print(".");
    Serial.print(", port ");
    Serial.println(Udp.remotePort());
    // read the packet into packetBuffer
    Udp.read(packetBuffer, 255);
    Serial.println("Contents:");
    Serial.println(packetBuffer);
Thanks for any help!
So in your receiving sketch, what is the packet size you get, and what
prints here?
a7
Forget about using booleans and Strings. All you need to send is 32 bits. On receipt of the 32 bits you can parse the individual bit values and use them to control your solenoids
Well I haven't decided what type of message to send yet since I don't know what would be the best to receive to control the different solenoids.
But if i send a 1 I get:
and if I send more ints i get 'list'
but if i send 'hey' I get the message that was sent, 'hey'.
But since Im just interested in boolean values I dont know if its best to send lists or ints? To keep byte usage down.
Ah thank you, this is kind of what i was expecting!
Would you mind telling me how to achieve that since I'm a complete beginner?
Which bit are you stuck on ?
I know very little about UDP. What type of data can you send and receive ?
Well now it is how to parse the 32 incoming bits from the UDP message and have them control the Arduino pins. Don't really know how I should go about handling the incoming UDP message to begin with.
What data type will the received message be in ?
Ideally it would be a uint32_t but 5 uint8_t variables would be just as good, if a little less convenient
Take a look at the bitRead() function to see how to get the value of a bit of a variable
I could format the message to uint32 but im not sure what message to send though to get the wanted bits?
oh the bitRead is great! I don't really get how to use it in my code yet but ill try it out!
If you can send and receive a 32 bit variable then you can use bitRead() to find the value of each of its bits and use it in place of a boolean variable
Okay, thank you I'll try it out!
Just to get me started can I ask how to handle the incoming UDP packet as a group of bits instead of as a char buffer?
why not as a single unsigned int?
output
decode: 2166653220 0x81248124
    0 0
    1 0
    2 1
    3 0
    4 0
    5 1
    6 0
    7 0
    8 1
    9 0
   10 0
   11 0
   12 0
   13 0
   14 0
   15 1
   16 0
   17 0
   18 1
   19 0
   20 0
   21 1
   22 0
   23 0
   24 1
   25 0
   26 0
   27 0
   28 0
   29 0
   30 0
   31 1
char s [90];
void
decode (
    unsigned long val)
    sprintf (s, "decode: %6lu 0x%08lx", val, val);
    Serial.println (s);
    for (int n = 0; n < 32; n++)  {
        sprintf (s, "   %2d %ld", n, val & 1L);
        Serial.println (s);
        val >>= 1;
  decode (0x81248124L);
wow thanks! That result looks like exactly what I'm looking for but I'm too new to Arduino to understand your code or how to implement this into my UDP setup...
presumably you're reading a ASCII string of a number representing a 32-bit value, for example, 2166653220 as in the code i posted. That string can be converted to an unsigned long using atol()
char s [90];
void
decode (
    unsigned long val)
    Serial.println (s);
        Serial.println (s);
        val >>= 1;
    if (Serial.available ())  {
        char packetBuffer [255];
        int n = Serial.readBytesUntil ('\n', packetBuffer, sizeof(packetBuffer)-1);
        packetBuffer [n] = '\0';
        unsigned long val = atol(packetBuffer);
        decode (val);
